Author Topic: CL5 and SB168-ES  (Read 721 times)
Eric Wilson
CL5 and SB168-ES
« on: October 13, 2018, 05:12:25 pm »
I'm attempting to get a CL5 to communicate with the older Ethersound-equipped Yamaha SB168-ES. The three players in this setup are the CL5, the SB168-ES, and the MY16-ES64 card (which gives the CL5 Ethersound capability).  The switches on the card are set as instructed by the manual.  The SB168-ES stage box works with the old M7CL console.  And I can't get the CL5 to sync with the SB168-ES.  Has anyone had experience in this setup?  TIA.
Eric Wilson
Steven Cohen
Re: CL5 and SB168-ES
« Reply #1 on: October 14, 2018, 03:20:55 pm »
Eric,
I have successfully installed the Ethersound stage box with a CL5 several years ago. Here is what I remember.
The MY16-ES64 card needs to be installed in slot 1 on the CL5.
You will need to install Auvitran software and use AVS control panel and possibly AVS monitor. Here is a link to the software,
https://www.auvitran.com/software/
That is all I remember about the installation. There were other steps such as setting the proper audio and remote directions within the Auvitran software and configuring the SB168 head amps in the CL5 I/O section, but I don't have the console close by. Coincidentally, I will need to install the same SB168 into a CL5 in the next month.
Here is a Yamaha document that goes over some of the steps to interface the SB168 to the CL5,
https://jp.yamaha.com/files/download/other_assets/3/798483/cl5_3_1_en_rm_e0.pdf
Hope this helps,
Steve
Eric Wilson
Eric Wilson
« Reply #2 on: October 14, 2018, 09:50:27 pm »
Thank you, Steve.
Eric,
Hope this helps,
Steve
Steven Cohen
« Reply #3 on: January 17, 2019, 05:28:50 pm »
Eric,
I am sure you have already configured the card but I now that I have recently transferred an Ethersound card from a MCL-7 to a CL5, I will add additional instructions that may help someone in the future.
The main adjustment that needs to be done is to tell the card where head amp control will be. This is done via Auvitran AVS monitor. I had to use a version from 2016 in order for the software to see the card and the stage box. I assume I could have upgraded the firmware in the card and perhaps the stage box in order to get the latest version of AVS monitor to work, but all I needed to do was to change head amp control from Mini YGDIA D-Sub 9 pin connection to Mini YGDIA Slot Internal Connection. This option is location in the control tab view of AVS monitor.
Steve
Thank you, Steve.
Page created in 0.057 seconds with 23 queries.
