Author Topic: call signal interface  (Read 754 times)
Brian Hancock
« on: October 11, 2018, 11:41:43 am »
guys got a question that hopefully someone can lend some knowledge to.
looking at sending 4 ch of standard tw clear com over fiber, i can make everything 4 wire on each end and send over an existing cobra-net infrastructure. question comes in when trying to relay call signals ... clear com makes a 4 ch hybrid which would work fine on each end IF4w4, but it doesn't have the necessary serial connections for call lights, alternately i don't see anything about it but could i use the FSII base gpio to relay calls? on one end ...
whats the best way to do this if there is one? ... 8 x ef-701m's would work but then i need 4 separate serial lines ... can this be done over ip suggestions?
finally seems like the LQ boxes could handle this and sent over ip and eliminate the need for the cobranet all together, but would probably need to carve out the network space ... anyone with experience with these boxes?
Aram Piligian
Re: call signal interface
« Reply #1 on: October 11, 2018, 02:51:48 pm »
I've used the LQ boxes a whole bunch, both with Helixnet and standalone (and with Freespeak too). Glad to answer any questions.
brian maddox
  • HeyYahWon! ttsss! ttsss!
« Reply #2 on: October 11, 2018, 08:44:37 pm »
I know this guy named Aram that has used the LQ boxes a bunch.  He could answer any of your questions.  :)
Seriously, the LQ stuff is super easy to use and uses very little bandwidth.  Plus you can plug 2-wire straight into it [if you use the 2W version] so it's super straightforward WRT the call thing.
brian maddox
bdmaudio@gmail.com
Page created in 0.066 seconds with 23 queries.
