Author Topic: QL 1/5 monitor mix questions  (Read 1063 times)
Kirby Yarbrough
  • Reston, Virginia
« on: October 09, 2018, 10:39:04 am »
Two questions for QL1 / QL5 console drivers:
1. Is there a fast and easy way to 'zero out' a specific mix (e.g., set all channel send levels to that mix to zero)?
2. Is there a fast and easy way to copy a monitor mix (e.g., set the specific channel send levels for one mix to be the same as another mix)?
These would be particularly helpful in working with mixes built from channels spread across two layers.  Thanks in advance.
« Last Edit: October 09, 2018, 11:41:11 am by Kirby Yarbrough »
Andrew Broughton
    • Check Check One Two
Re: QL 1/5 monitor mix questions
« Reply #1 on: October 09, 2018, 12:57:36 pm »
1. I think Channel Job/Default would work, just set the parameters you want to zero. i.e. the Mix Sends.
2. For Mix to Mix, probably Channel Job/Copy from one mix to another, with "With Mix Send" selected.
-Andy
Kirby Yarbrough
  • Reston, Virginia
« Reply #2 on: October 10, 2018, 09:29:33 am »
Thanks very much.  The copy solution works a treat, but I've not found any selectable parameters for the default function.
Scott Helmke
« Reply #3 on: October 10, 2018, 09:57:16 am »
The easiest way I've found for resetting mixes to zero is just to go into Sends on Fader and push all the faders down. It's quick enough that I never bothered to learn the official way to do it.
Kirby Yarbrough
  • Reston, Virginia
« Reply #4 on: October 10, 2018, 10:34:24 am »
The ‘Fast Swipe’ technique.
brian maddox
  • HeyYahWon! ttsss! ttsss!
« Reply #5 on: October 10, 2018, 11:29:39 am »
brian maddox
bdmaudio@gmail.com
Justice C. Bigler
  • Tulsa, Oklahoma
    • My homepage
« Reply #6 on: October 10, 2018, 12:12:20 pm »
Otherwise known as the "oh shit, I fucked something up" method.
Justice C. Bigler
www.justicebigler.com
Matthew Knischewsky
« Reply #7 on: October 10, 2018, 12:31:21 pm »
Same here!
  • Old enough to know better
  • Audio Plumber
« Reply #8 on: October 10, 2018, 12:47:02 pm »
To clear many aux sends quickly, I go to mixer setup, turn them all into fixed mixes, then turn them back to variable mixes.
Riley Casey
« Reply #9 on: October 10, 2018, 01:28:15 pm »
Where is the like button when you need one?
Page created in 0.068 seconds with 23 queries.
