Pages: 1 [2] 3 4   Go Down
Author Topic: Converting peak limiter to RMS limiter  (Read 1475 times)
Re: Converting peak limiter to RMS limiter
« Reply #10 on: October 08, 2018, 01:53:22 pm »
You can't "convert" Peak limiting to an RMS value; those have to be independently created as they are based on different criteria.
David Sturzenbecher
  • So. Dak.
    • Sturz Audio
« Reply #11 on: October 08, 2018, 02:01:10 pm »
I think he means single where it waits for a signal to cross the trigger threshold and measures from that point forward?
Correct, Y axis is still voltage, X axis is still time, however the time is continuous
Attached is a rather crude example.  Here is was looking at the time constants for thermal limiters on a bridged amp.
Audio Systems Design Engineer
Daktronics, Inc.
CTS-D, CTS-I
AES Full Member
Frank Koenig
« Reply #12 on: October 08, 2018, 02:03:10 pm »
You can use a peak voltage limiter with a long attack time as an approximation of an average power limiter, but in doing so you're assuming a constant crest factor (ratio of peak to average value) of the signal. A limiter based on the root-mean-square of the voltage is a better approximation of an average power limiter, assuming only a constant load resistance. To measure true average power you need to average (low-pass filter) the product of the instantaneous voltage and current, and some amps can do this. You get into trouble, however, if you have varying numbers of speakers in parallel, not to mention the problem of one speaker going open circuit and killing the other. We've covered this ground on this forum not long ago.
If you want to verify the differences between limiters on the bench you need to use a test signal with variable crest factor, such as a pulse train of varying duty cycle or variable crest factor noise (now synthesizing that is cool). But you can get pretty far with sine waves, tone bursts, and a little faith in the instruction manual combined with some common sense.
--Frank
Yes, it is a giant stereo system!
Nathan Riddle
  • Niceville, FL
    • Nailed Productions
« Reply #13 on: October 08, 2018, 02:07:33 pm »
What are those criteria?
If what Mark said about the PLD limiters is true (that they are simple limiters) then wouldn't the time constant (attack/release times) just change to allow for more of an average level?
Be back later, I gotta prep me home for a hurricane :)
Mark Wilkinson
« Reply #14 on: October 08, 2018, 02:09:51 pm »
Do you recall if the peak works on peak or rms voltage?
While you might be bummed (sorry), I busted out laughing and thoroughly enjoy the candor  :D
Peak works on rms voltage too.   Take a look at max peak voltage setting available, and you'll see it's only 155v.
Yeah, you gotta laugh....I sure did... I'm pretty good at laughing at myself , get lots of opportunities to practice it lol
The spider-to-former ring of glue broke....don't really know what to think...can't pinpoint when it happened....
Help please anybody !
Mark Wilkinson
« Reply #15 on: October 08, 2018, 03:04:11 pm »
Thanks,  OK I see how to use roll mode for checking thermal.  Thermal attack is slow enough to see....
But peak?  With peak's much shorter attack?  vs roll mode's parameter limit?  200ms minimum on mine (ds1054z)
David Sturzenbecher
  • So. Dak.
    • Sturz Audio
« Reply #16 on: October 08, 2018, 04:42:52 pm »
I had no problems looking at peak attack times down to the individual cycle.   I am on the same DS1054Z.
Daktronics, Inc.
CTS-D, CTS-I
AES Full Member
Mark Wilkinson
« Reply #17 on: October 08, 2018, 04:47:15 pm »
Thanks David, I see.
Mark Wilkinson
« Reply #18 on: October 08, 2018, 04:55:44 pm »
I think it may be more of a combo of what i think I measure, and what Tim was saying...
Because the rms limiter voltage setting pretty well matches measured amp output, where the peak voltage limiter setting typically measures 5-10 volts lower (rms measurement).
So there appears to be some kind of algorithm in play....sorry if oversimplified.
Peter Morris
« Reply #19 on: October 08, 2018, 07:55:04 pm »
I think the terminology gets butchered a bit between manufactureres, publications, forums, etc. I'm trying to see through the veil  :)
I was trying to state that with the HPF set according to manufacture recommendation over excursion would be taken care of.
Taken from Nick here:
https://soundforums.net/community/threads/help-me-understand-system-limiting-setting-it.1139/page-2
There's also talk of a difference between a true RMS limiter and a thermal limiter.
Perhaps there is no need for an additional rms/peak limiter when using a thermal limiter and the amp can't send peak voltage?
In general a well set HPF will offer protection, but you have to remember that it is not a limiter and if you try hard you can still have issues.
Letís say the filter is 12 dB per octave at 40Hz (i.e - 12dB @20Hz) .Ö so if the DJ for example pushes all the LF GEQ faders up by 12 dB to get more bass (as I have seen) then you will still have full drive at 20Hz and Xmax issues.
The trick is to put the limiter before the HPF so you can't get the extra 12dB of drive.
The problem when you exceed Xmax is the voice coil comes out of the gap and the thermal capacity drops dramatically because the coil no longer has the magnet assembly to wick the heat away.  Usually its worse that we think because most driver donít behave very well at extreme Xmax situations and develop some offset with their cone position. Itís due non symmetrical magnetic flux and suspension behaviour. (Klippel BL measurements) Ö this is why you see drivers with the coil burn at one end.
Luckily for many subs their impedance over their operating range is quit high, think in terms of twice their nominal rating so the heat build up is not as bad as we might first think.
Generally you see peak limiters come more into play with compression drivers, they often see huge peaks but the average power can be quite low. The peaks can break the voice coil assembly, shatter the diaphragm or blow the first part of the coil winding like a fuse. You usally set the rms limiter time constants to allow the peaks / transients through to the driver so the music still sounds dymanic and real and then catch the dangerous peaks with the peak limiter.
The trick with limiters is finding a solution that still allows you to take full advantage of the speakerís capabilities but at the same time protecting them from stupid operators.
« Last Edit: October 08, 2018, 10:17:11 pm by Peter Morris »
Pages: 1 [2] 3 4   Go Up
Page created in 0.054 seconds with 23 queries.
