Author Topic: Yamaha LS9-32 question  (Read 1803 times)
Alan Ellison
Re: Yamaha LS9-32 question
« Reply #10 on: October 09, 2018, 11:40:27 am »
You're right in that it would be as simple as connecting both channels of the KeysOut to two channels on the LS9, and panning one left and panning the other right. Good idea to then "channel link" at this point, so future gain/fader changes will affect both channels simultaneously. [CHANNEL JOB --> CH LINK; press and hold "sel" on the first channel, and while doing so, press "sel" of second channel will link the two. Make sure your settings like fader position and gain are already matching before doing this, otherwise the console will memorize the difference between the two and keep that consistent as well.)
Outputs: Yep, check that both Omni15 and Omni16 are in use. Double check the output port assignment to ensure that they're being fed StereoL/StereoR as opposed to a matrix or other output option.
-Ray
Thanks Ray, this is the info I need to hear. Where do I check the output port assignment please? Like, in what menu ?
Ray Aberle
    • Kelcema Audio
« Reply #11 on: October 09, 2018, 04:46:06 pm »
Alan,
Use the SETUP button. There's several menus, so you need to cycle through them until you reach the SYSTEM SETUP screen. Right in the middle of the screen is the "OUTPUT PORT SETUP" area. Select OMNI 9-16; this is where you can see what is patched to that group of 8 outputs. This is also where you'd reverse the phase or apply output delay.
-Ray
Kelcema Audio
Alan Ellison
« Reply #12 on: October 10, 2018, 03:47:31 pm »
Alan,
-Ray
OK, thanks again Ray, I will look into this, with this info at least I can be more effective.
Page created in 0.056 seconds with 23 queries.
