Pages: 1 ... 23 24 [25] 26   Go Down
Author Topic: New Midas console?  (Read 70193 times)
Brian Hancock
Re: New Midas console?
« Reply #240 on: May 06, 2021, 10:12:54 AM »
https://forums.prosoundweb.com/index.php/topic,168821.0.html check this thread from a while back the 9620 and larger sibling work same way as far as the optical transmission goes ... rack it put I'm an st patch with sm bidi sfp and an lc to st jumper and away you go ... st is basically standard field tatical fiber ... you can buy it cheaply, repair easy and subrent abundantly ... as as mentioned before its really standard in buildings nowadays that are fairly modern plenty of arenas etc. Work great just used this on a show this week with a pro 2 fyi.
keven mcdonald
« Reply #242 on: May 08, 2021, 04:12:47 PM »
Optocore is definitely not MM only... we use Broaman video products (parent/sister company of optocore) along with digico consoles to pass a whole bunch of stuff with CWDM using a mux22 unit, and do it all using singlemode expanded beam HMA connectors. In fact, you can spec digicos with these connectors from the factory.
Andrew Broughton
    • Check Check One Two
-Andy
Russell Ault
  • Edmonton, AB
« Reply #244 on: May 09, 2021, 05:50:33 PM »
Good to know! That must be a recent(-ish) change; this Optocore cabling document (which, admittedly, is dated from 2008) only talks about MM.
-Russ
Andrien (No Last Name)
« Reply #245 on: August 18, 2021, 04:17:41 AM »
News, there is an editor for Mac/Windows for HD96, you can grab it on MCloud.
« Reply #246 on: August 18, 2021, 12:44:56 PM »
Update - I have seen and touched (but did not mix on) the HD-96.
What I know - there is a shipping container "on the water" that has an initial allocation for North America.  There are more units currently in production at Behringer's China factory.
USA MSRP, with case, cover, etc is $39k.  Discounts may be available.  DL 1/2/3/4 series i/o  not included in that price.
Matt Marcus
« Reply #247 on: August 21, 2021, 06:35:57 PM »
Please explain- what/where is MCloud?
« Reply #248 on: August 21, 2021, 08:14:20 PM »
A big, fluffy water vapor bag filled with Midas blinking red lights...
The HD96 can upload/download show files and libraries to the Midas Cloud; it's also the repository for manuals (which can then be read/viewed on the console screen), firmware, etc.
« Reply #249 on: August 21, 2021, 10:20:07 PM »
That and probably some security implication if you didn't set a pretty secure password for the console  8) Not sure how secure the linux kernel they use on the console, but still probably better than Windows XP running on some other console.
Pages: 1 ... 23 24 [25] 26   Go Up
Page created in 0.031 seconds with 20 queries.
