Author Topic: aes50 extender 9620 fiber  (Read 1453 times)
Brian Hancock
« on: October 02, 2018, 03:15:33 pm »
anyone have any experience with this ...
9620 - has mm fiber transmitter which is great if you are going short distance but if your infrastructure is sm and you need longer distance sm is the way to go.
looking for any advice or thoughts on the following thread which is the only place i can find any information about it on the googles.
sorry for the link if it needs to be deleted please let me know. https://forum.musictribe.com/showthread.php?17802-Dn9680-x32-amp-sd8/page2
I'm assuming midas would direct me to a 9680 which is 4times the cost and way more power that what is needed thanks in advance.
Christian Ekren
Re: aes50 extender 9620 fiber
« Reply #1 on: October 02, 2018, 05:36:24 pm »
Looks like the attached thread pretty much sums it up.
9620 can be modified to use a single-mode SFP module if needed. I don't think anyone is going to direct you to the 9680 if you're using an x/m32 system, as it does not support control over AES50 (i.e. headamp, phantom, etc.)
Kevin Maxwell
« Reply #2 on: October 02, 2018, 06:41:57 pm »
When using the copper (cat5) connector does it use a different protocol then the AES50 and is it susceptible to the same issues as the AES50 cabling? Like Interruptions or loud noises if stepped on.  If it has the same problems then what is the purpose of using a dn9620 with Cat5 cabling? I assume that it is different since it looks like it carries both AES50 A and B.
Brian Hancock
« Reply #3 on: October 02, 2018, 08:14:53 pm »
supermac vs hypermac ... think 100 mbps vs 1gbps
less cabling ... never had it pop or drop out when moving or stepping on a cable but also using link tactical cat or belden tactical
was more looking to see if anyone besides this one thread had done as much ... the reason for the 9680 is they do specify a sm or a mm version of it but it's a 1k plus item for just 1 end.
nope pro series desks specifically
thanks guys
Brian Hancock
« Reply #4 on: October 10, 2018, 09:09:29 am »
so just got the 9620's in threw in some cisco compatible sfp's updated the box's firmware and nothing ... it won't connect ... spoke with sfp vendor after pulling out mm sfp's and ordered up a second set ... this was my fear as there are so many different firmware versions of sfp's it doesn't matter if the light is compatible it all boils down to if the device is able to speak to the sfp ... so frustrating ...
Jon Dees
« Reply #5 on: October 10, 2018, 10:30:21 am »
How about calling these guys? This may be dumb enough to do what is needed
https://www.aflhyperscale.com/product/mm-to-sm-media-converter
Brian Hancock
« Reply #6 on: October 11, 2018, 09:42:45 am »
so seems as though the op in the linked thread in the first post had luck with "Cisco" type sfp's they were not compatible with the device.  after speaking with the helpful people at fs.com they got us squared away it appears the sfp was actually a dell type but their generic sfp's worked fine and the 9620 recognized them right away ... we really didn't want to have to have a different fiber patch as SM fiber is all our inventory is and quite prevalent in the work we do as an install ... 22 bucks later we have a sm bidi 1310/1550 device that works on 1 fiber strand for 20km ...
Eddie Richardson
« Reply #7 on: December 02, 2018, 03:40:14 pm »
Brian, we have wanted to put AES50 from our X32 to our S8 and S16 for years. We too use singlemode fiber. Can you share any more details or descriptions of how hard the switch to different SFPs was and what steps you took. Also the bidirectional SFP is very appealing so we donít have to use 2 fiber strands and only have to use one. Do you mind sharing the make/model number of SFPs that worked in the 9620 with singlemode?  Also Iím assuming everything from preamp controls, etc work?
Thanks a ton!!
  • Old enough to know better
  • Audio Plumber
Posting Rules
« Reply #8 on: December 02, 2018, 05:11:32 pm »
admin
Brian Hancock
« Reply #9 on: December 05, 2018, 02:07:48 pm »
Thanks a ton!!
Eddie ... if you open your 9620 you will see the small sfp is attached to a short lc to lc multi mode jumper.
simply pull this and the sfp ... we have worked with fs.com for a while now on different stuff reached out to our account rep there ... as with posts on midas's forums we initially got cisco compatible ones but no go ... we read off the sfp specs to fs.com and they were able to match it to one of their off the shelf items.  i think less than 20 bucks each end. https://www.fs.com/products/29892.html and its partner plus a short lc to lc single mode jumper.
the wdm sfp uses 1310 and 1550 but you can get in various wavelengths just be sure you get the inverse for the other end so 1310tx and 1550rx on one side would mean 1550tx and 1310rx on the other side.
you can still use the opticon connection (just need 1 of the 2 sides) and we convert everything to st anyway because thats our standard so a second short lc to st jumper and a barrel and off and running.
we also made sure we had most up to date firmware - usb flash uploader -- used a few shows already to go few thousand feet
its a standard ethernet based sfp you can rely on the stated specs ... 10km rated was enough for most of our applications ... i think we sent it through about 5000 ft of tac 4 in the shop and all seemed very happy.
« Last Edit: December 06, 2018, 10:26:31 am by Brian Hancock »
Page created in 0.073 seconds with 22 queries.
