Pages: [1] 2 3  All   Go Down
Author Topic: Inexpensive Lavs  (Read 1437 times)
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
Inexpensive Lavs
« on: October 01, 2018, 06:53:15 pm »
I think I have used a lav one time in the past 10 years or so.
I have a W93 and one with no label other than Shure on it. I have some headsets which are mostly what my belt packs get used for.
I need a couple of (presumably Omni) lavs for a wedding.
I expect one on the lapel of the groom and one on a bookmark for the officiant.
These are likely one use given how often I am likely to use them so I donít want to put huge money into it.
If someone close to me has some I could rent, that might work too.
So, what do you suggest? I have Shure ULX gear.
Thanks
(Brian) Frost
Re: Inexpensive Lavs
« Reply #1 on: October 01, 2018, 07:10:53 pm »
Why not rent since you are basically never using them.  my company would rent wl50 lavs for $10 ea.  but we arent local.
Thanks
brian maddox
  • HeyYahWon! ttsss! ttsss!
« Reply #2 on: October 01, 2018, 09:04:10 pm »
PM sent
brian maddox
bdmaudio@gmail.com
Brian Jojade
« Reply #3 on: October 02, 2018, 01:05:06 am »
Definitely rent, and rent good stuff.  Cheap lavs are a nightmare, especially for live reinforcement work.
When working with lav placement, realize how far away you are placing the mics.  Consider what would happen if you put a regular mic that far away from someone.  Would you expect to get good results?  If not, then a lav won't magically make it work any better.
Brian Jojade
Russell Ault
  • Edmonton, AB
« Reply #4 on: October 02, 2018, 01:48:53 am »
+1 to everything here. The smoother the frequency response (on and off axis) the less likely they are to feed back, and the more likely they are to be expensive...
-Russ
Mike Monte
    • My website
« Reply #5 on: October 02, 2018, 08:22:45 am »
Thanks
I provide one lav mic for several outdoor weddings per year.
I will clip the lapel mic to the officiant's binder (at the top of the spine).
I have found that I can run the mic pretty hot...
This way I get the officiant's voice when he/she speaks and I also get the bride and groom's voices as they respond (since the officiant faces each one of them as they recite).
One thing that you may want to aware of: Make sure that the lav pack is in its own pocket...
a case in point:
Two years ago I provided the lav for an outdoor ceremony; prior to the ceremony I mic'd up the Rabbi, tested it, got a level at the ceremony site, muted it, all set.
The ceremony starts and there is an abundance of static in the PA.... I adjusted the gain, etc, and eventually had to shut it off...
Upon conclusion of the ceremony I went to the Rabbi and discovered that the "videographer" had also put a wireless mic on the Rabbi and put his pack in the same pocket as my pack...so that the two units were touching...
Did the addition of the videographer's pack cause the static....who's to say, but I tested my lav at the ceremony site after the the ceremony and it worked fine....
Food for thought...
Stephen Beatty
« Reply #6 on: October 02, 2018, 08:52:02 am »
 Having done local theater groups and having gone through a number of mics I found the Microphone Madness MM-PSM-L (omni)  have been really nice.
 Of the original 6 I purchased they are all still working. Easy to mount, I like to use them through the hair mounted if I can. They have been very dependable and sound great for spoken work or singing.
Edited for: I just saw the one time use thing. If I was close you could borrow them.
« Last Edit: October 02, 2018, 08:55:23 am by Stephen Beatty »
Scott Olewiler
    • 4th Street Sound
« Reply #7 on: October 02, 2018, 09:59:22 am »
Small swerve:
We rent lavs  at least twice a month  for weddings where we deliver, set up, test and leave. So no paid operator on site for the ceremony and the officiants  are rarely on site during the set up. Usually the DJ runs the small mixer we provide.
I always tell the clients ( usually the groom and the DJ if he is there) to put the mic on the binder but I find that once the  officiants show up they almost always insist they  wear them on their lapels.
Do you have some magic phrase you use to convince the officiants that the binder is the best place?  My guess is that the groom just doesn't present the authority I have on the few occasions where we are providing an operator, and they just cave to whatever the officiants wants.
Maybe I should leave typed instructions?
If you want to feel more Kick drum turn up the kick drum fader, not the damn subs.
Mike Monte
    • My website
« Reply #8 on: October 02, 2018, 01:31:11 pm »
Let me preface:  I lead a classical trio/quartet that performs extensively in the Rhode Island wedding circuit.  I provide a lav for the officiant for an additional fee if requested.
I am very cordial.... after introducing myself to the officiant I always say, "let's try this..."
I actually learned the lav-on-binder technique several years ago from an officiant (retired priest) that performs for many outdoor ceremonies in the Newport, RI area.
On that particular gig I asked him where he would like the lav to be clipped...his answer "right here" (pointing to the spot).
I gotta give credit where credit is due....
Tim Hite
    • Bad Quail
« Reply #9 on: October 03, 2018, 03:34:00 pm »
I just did lab on an atlas for a wedding over the weekend. It worked OK. Trying to convince the officiant that it would be OK was tricky. She wanted a handheld until I took her to the ceremony are and showed her how it all went together. I put an E6 earset on her, which worked just fine.
Bad Quail
Sound + Light
Joshua Tree, California
Pages: [1] 2 3  All   Go Up
Page created in 0.083 seconds with 21 queries.
