Pages: 1 [2] 3  All   Go Down
Author Topic: Rats! Need an armored AC mains cable  (Read 3559 times)
Re: Rats! Need an armored AC mains cable
« Reply #10 on: September 25, 2018, 06:30:30 pm »
Yes, this is what I'm using for speaker hook up.
I still need to cover an IEC mains cable from outlet to amplifier and I'm trying to find a solution for that issue. The IEC plug eon't fit down 3/4" conduit and I can't seal the end to keep stuff out.
Also can't seem to find cable ends to build my own out of the MC cable.
https://www.alliedelec.com/schurter-4782-0100/70080654/
Erik Jerde
« Reply #11 on: September 26, 2018, 01:49:28 am »
If you’re fine with the cable being outside other than the rats then it really shouldn’t matter if stuff gets in it.  For the IEC cable not fitting just chop off the Edison plug end and replace that after fishing through your armor of choice.  Leave the molded IEC alone.
Tim Hite
    • Bad Quail
« Reply #12 on: September 26, 2018, 03:53:59 am »
How'd you find that? Been looking for a couple days.
Doh, I forgot cables have two ends.
Bad Quail
Sound + Light
Joshua Tree, California
Keith Broughton
  • Toronto
« Reply #13 on: September 26, 2018, 07:08:32 am »
I didn't know what MC stood for. I know it as BX.
As suggested, plastic conduit may be the most cost effective solution.
Tim Hite
    • Bad Quail
« Reply #14 on: September 26, 2018, 08:56:52 pm »
Similar but different, I guess. . .
http://www.ncwhomeinspections.com/BX+Cables+on+exterior+installations
Now that Scott found the magical missing piece for me I can just make up what I wanted.
Bad Quail
Sound + Light
« Reply #15 on: September 26, 2018, 10:37:24 pm »
Cool, those are real useful for making all sorts of custom cables.  If they made lockers my life would be complete
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
« Reply #16 on: September 26, 2018, 11:33:37 pm »
I had some 2” pvc from my house out to the street for the cable company. I sealed up the end with an end cap that I drilled for the wire and cut a slot from the hole to one side. I slid it over the wire, then on to the pipe coming out of the ground and used duct seal for the slot.
Tim Hite
    • Bad Quail
« Reply #17 on: September 27, 2018, 02:37:38 pm »
So, after searching for requirable IEC plugs for two days and not finding anything, I put "IEC Plug Lock" into google and this comes up first shot:
https://www.amazon.com/Rewireable-IEC320-C13-Accidental-Unplugging-Disconnections/dp/B01DCFVXKK
I was going to refer you to another product that I can't find now. Someone makes a clip that thread onto the panel mount receptacle mounting screws. Here's one you can retrofit. There's another that clips all the way over the IEC cable end and there's one for NEMA 5-15 as well.
http://www.interpower.com/ic/designers/in-depth-product-line-information/More-information-on-Connector-Locks.html
Bad Quail
Sound + Light
« Reply #18 on: September 27, 2018, 04:11:51 pm »
Indeed I am aware of those but these need to be compatible with the locking IEC's on our QSC boxes.
Very specific requirement.
Jonathan Johnson
« Reply #19 on: September 28, 2018, 04:35:18 pm »
The price is a little “out there” but a search for “armored extension cord” returned this...
100' 1/3 HLMC Armored Metal Clad Extension Cord - 250V - 3100 Plug and Connector https://www.amazon.com/dp/B074F3FGJP/
Pages: 1 [2] 3  All   Go Up
Page created in 0.044 seconds with 22 queries.
