Author Topic: help please - how to control LED light bar  (Read 1321 times)
Ken Maytom
« on: September 15, 2018, 09:03:47 pm »
I bought 2 X 4 par lights bar - only to find out that they don't have any inbuilt programs or sound activated functions
I just want to have these on either side of stage for my pub band - turn them on and we have a very basic light show
They have DMX in and out - i have tried to get another sound activated light to control these but no success
i am an absolute novice and don't want to go down the dmx controller path
Is there something i can plug into these bars
« Last Edit: September 16, 2018, 02:29:43 am by Ken Maytom »
Re: help please - how to control LED light bar
« Reply #1 on: September 15, 2018, 09:06:10 pm »
You first need to update to your real name per the rules when you created your account before anyone can help you.
Sent from my VS996 using Tapatalk
River Delta Audio is now:
Jeff Lelko
  • Cape Canaveral, FL
« Reply #2 on: September 16, 2018, 12:28:42 am »
Yes - a DMX controller.
I don't mean to sound blunt, but if they don't have an auto mode, a sound-active mode, or work with an IR remote, you don't have a choice.  A DMX controller doesn't have to be expensive or complicated, but unless you're holding something back about what you bought there is no way around it.  You'll either have to buy a controller or replace these fixtures with something that works the way you need it to.
Ken Maytom
« Reply #3 on: September 16, 2018, 02:22:39 am »
not holding anything back - i was hoping i could use another light - i bought this which was supposed to be dmx master - but i cant get it to control the bars
Jeff Lelko
« Reply #4 on: September 16, 2018, 02:42:30 am »
DMX doesn’t work that way.  What does the manual tell you for the LED bars in question?  Unless it says anything other than “This unit must be used with a DMX controller”, you’re out of luck for alternate options.
Ken Maytom
« Reply #5 on: September 16, 2018, 04:33:03 am »
No manual unfortunately
Lee Douglas
  • 47.662615, -116.756954
« Reply #6 on: September 16, 2018, 09:55:20 am »
Manufacturers?  Model number?  Pretty important stuff.
This space for rent
Paul G. OBrien
« Reply #7 on: September 16, 2018, 04:55:22 pm »
So you got generic chinese fixtures then. If so no loss about the manuals.. they typically contain next to zero useful information. Bottom line though is you will need a DMX controller of some type for these things.. no way around it. With that in hand you can then figure out how to control these lights.. with some help.
Ken Maytom
« Reply #8 on: September 17, 2018, 04:01:06 am »
Lumicraft Lumistage 4/146/10
a little research helps - sorry i should have done this first
It appears that it does have a 'sound-to-light' mode - just have to figure out how to set it up correctly
i have found the below spec sheet - but no instructions
http://www.lumicraft.com/?dl_id=11
your help is greatly appreciated
Thanks
Ken
Lance Hallmark
  • Tampa Bay, FL
    • Hallmark Events & Entertainment
« Reply #9 on: September 17, 2018, 11:09:42 am »
Thanks
Ken
There are 10 chase patterns built in and 10 sound mode patterns and 20 scene modes for this fixture. Those can be manually selected via the built in menu on the fixture.  Each light can also be controlled separately for color, brightness, strobe via DMX. If you are OK running one of the built in patterns you can just set it manually. If you want full control to change the patterns. colors, etc.. you will need either a DMX controller (like a Chauvet Obey) or use their recommended Lumicon 43 controller or the optional IR remote (probably the easiest solution).
When a fixture has a master/slave control, the device that is set to master will control additional fixtures of the same model that are set to slave.  It will not control different fixtures properly.
Lance Hallmark
Chamsys, Crown, Danley, EV, JTR, Powersoft, Yamaha
Page created in 0.055 seconds with 22 queries.
