Pages: 1 [2] 3 4 5   Go Down
Author Topic: Cisco SG300 EOL, SG350 OK for dante?  (Read 7041 times)
Tom Bourke
    • http://www.cwalv.com
Re: Cisco SG300 EOL, SG350 OK for dante?
« Reply #10 on: September 17, 2018, 11:10:44 pm »
I guess that depends on what your definition of "not too expensive is". Last time I looked the Yamaha switches were approaching $2,400. The SG300-10 was only about $160.
And I need 4 for redundant network!
Justice C. Bigler
  • Somewhere between the Atlantic and Pacific
    • My homepage
« Reply #11 on: September 18, 2018, 01:36:49 am »
I have four SG300-10s in the jazz club that I designed and is about to open in a couple weeks. They probably cost not much more than $600 for all four. No way would I be able to to install four of the Yamaha switches in this club.
Justice C. Bigler
www.justicebigler.com
Head Audio/A1 Blue Man Group North American Tour
Tim Hite
    • Bad Quail
« Reply #12 on: September 18, 2018, 04:26:30 am »
I wasn't trying to sound cavalier about money. There's an 8-port version without fiber for ~$1000. Certainly seems to tick a lot of the boxes for what I've seen people asking for on PSW.
VLAN has option to configure with DIP switches so you could do a redundant network with only two of them without having to get into the weeds with switch management.
Bad Quail
Sound + Light
Joshua Tree, California
Steven Barnes
    • SBTS Inc.
« Reply #13 on: September 18, 2018, 09:48:40 am »
I have used many variations of the SG350 and SG550, they all work fine for Dante and are all non-blocking switches (full bandwidth on all ports through the backplane). The new SG350 is essentially the old SG500 with the higher bandwidth SFP ports.
If you are looking at the Yamaha switches, I would check out the Luminex stuff. They are expensive, but offer some stupid easy configuration software for VLANs, and have preconfigured options for various production protocols that is nice if you are changing switch configurations often.
Audio Engineering, Design, Consulting
SBTS Inc.
www.sbts-inc.com
Amek Anson
« Reply #14 on: November 19, 2018, 01:07:59 pm »
Question:
Cisco SG300 or 350 SFP Port, The MGBSX1 on Dante can supports up to 500 m?
Yamaha SWP transmission over distances of up to 300 meters? can More?
Multi Mode or Single on Dante any Different? Any one would be better?
i use Neutrik OpticalCon Duo X-Treme(Multi Mode) can Run Up to 500m?
Thanks
Steven Barnes
    • SBTS Inc.
« Reply #15 on: November 19, 2018, 01:36:37 pm »
Question:
Thanks
- Yes this will do 500m with 850nm multimode fiber. This will be a 1Gb connection which should be more than enough for Dante.
- Max distance per Yamaha is 300m. I wouldn't go any further if that is the max spec.
- Single Mode will give you significantly more distance as it is laser based. Distance are in the 10-40km range with the correct transceivers.
- Multimode is typically what you will see for shorter distances (under 1500' or 500m).
- Both work fine for Dante, it is all just basic network infrastructure.
- With the correct transceivers you should be able to go 500m depending on the multimode you are using.
SBTS Inc.
www.sbts-inc.com
Greg Bellotte
  • SLC, UT
    • www.MambaFiber.com
« Reply #16 on: November 19, 2018, 02:53:34 pm »
I'm using aftermarket SFPs from FS.com (single mode bi-directional) in my SG300/350 switches. Max distance between units to date is about 12,000ft/roughly 3.5kM. No issues...
timing is everything...
www.MambaFiber.com
Amek Anson
« Reply #17 on: November 19, 2018, 11:24:59 pm »
Thanks
Amek Anson
« Reply #18 on: November 20, 2018, 02:03:07 pm »
Use two Yamaha SWP for FOH & Stage L, The Stage R use Cisco SG300, can?
Miguel Dahl
« Reply #19 on: January 15, 2019, 06:44:45 pm »
Looking into getting some new switches. I've understood that the SG300 is/was somewhat of a "reference" Dante switch (Audinate use them as examples).
Is the 350 a safe bet? They are way cheaper than the 300's.
Pages: 1 [2] 3 4 5   Go Up
Page created in 0.044 seconds with 24 queries.
