Pages: 1 ... 3 4 [5] 6 7   Go Down
Author Topic: Current model JBL SRX boxes induce buzz in mic cables/channels  (Read 4279 times)
Michael Kofei
Re: Current model JBL SRX boxes induce buzz in mic cables/channels
« Reply #40 on: September 28, 2018, 12:01:06 pm »
Are you absolutely sure there is nothing else going on with the AC in the building?
This ^ is what I was going to suggest as well.
Sounds like you have an electrical power issue — in the wall/building. It just doesn’t make sense to me that all of your mic cables that apparently worked flawlessly are now failing, nor that JBL made a shit PSU and no one until now discovered it.
Dave Garoutte
  • San Rafael, CA
« Reply #41 on: September 28, 2018, 12:37:47 pm »
I had an intermittent buzz happening in my bass preamp for a while.
I sent it back to the (local) manufacturer to check out.
They found nothing, but it kept buzzing.
I finally realized it was coming from the high tension wires passing over my shop when the humidity was high.
BzzZZP.
Inventor.
Adam Kane
  • Battle Creek, MI
« Reply #42 on: September 28, 2018, 02:02:53 pm »
I believe Greg stated earlier in the thread that this problem has been present in more than 1 venue and power system (distro vs no distro, etc).
Greg_Cameron
    • Cameron Pro Audio
« Reply #43 on: September 28, 2018, 04:21:45 pm »
It seems ridiculous to have to move from the Whirlwind cables to the star-quad.
Have you tried duplicating the problem in a different building?
Just for kicks, I would put a ground lift adapter on the AC cord feeding the buzzing JBL just to be sure it isn't some type of ground loop.
Yeah, if you read back through the posts, you'll see I had this happen in more than one location. My first suspicion it was the JBL boxes causing it was back in August at an outdoor stage. Completely different AC supply and location. Buzz cleared when I pulled the plug on one of my wedges. As far as ground lifting the AC on the noise source speaker, I could give that a go. There's no ground loop per se since there's no signal cable plugged not the JBL. I figure if there was some other noise source coming up the ground wire from the AC supply, it would be present as well when plugging into the EV speaker with the same power cord pulled from the JBL in the first video.
Greg
Cameron Pro Audio
Greg_Cameron
    • Cameron Pro Audio
« Reply #44 on: October 11, 2018, 05:58:02 pm »
Update:
Got a shielded power cord to test. Didn't appear to make a difference which would lead me to believe the noise is living on the ground bus. Looks like new mic cables is the only solution at this time aside from replacing the speakers.
Greg
Cameron Pro Audio
Debbie Dunkley
  • Central North Carolina
« Reply #45 on: October 11, 2018, 10:23:40 pm »
Update:
Greg
Sorry to hear that Greg. Did you hear back from JBL ?
Adam Kane
  • Battle Creek, MI
« Reply #46 on: October 12, 2018, 11:45:32 am »
Seems to m that there may have just been a (possibly) small run of these things that have this issue since this doesn't look to be widespread. I'd be demanding that JBL take these back and fix/replace them. The mic cables you're using now are no joke, and you shouldn't need to replace them or pay so much attention to placement just to be able to make it through a show.
Dan Mortensen
« Reply #47 on: October 12, 2018, 11:48:48 am »
To be clear about this, the "Pin 1 Problem" has nothing to do with loops and everything to do with the path to ground on device input connectors.
Neil Muncy (R.I.P.) discovered that devices using foil traces to connect pin 1 to ground had buzzes occur when the RF induced upon cable shields exceeded some random amount. The foil traces, not being very robust in mass(?) diameter(?) compared to an actual wire, would act as resistors and not immediately dissipate all the RF to ground. Instead the RF would get into the circuitry of the mixer/power amp/whatever that the input was feeding.
Replacing the foil trace with an actual wire of even modest size eliminated the problem, as does making the foil trace be huge enough in width rather than skinny.
Not sure how relevant this is to your problem, but that detail should be stated correctly and I hope this is closer to correct.
It's encouraging but still troubling that quad cable clears up the problem.
My money is on unannounced value engineering of the power supply. Anyone else with new boxes?
Andrew Broughton
    • Check Check One Two
« Reply #48 on: October 12, 2018, 12:32:05 pm »
You and Debbie should exchange amp photos and date/model/serial info to figure out if it's something in a specific manufacturing run. Did you buy them all together? Are the serial numbers close? Can you get another one of your boxes from a local supplier to test and see if you reproduce the issue with a box other than your own, from a different manufacturing run (earlier or later, or both if possible!).
These things will tell you whether it's a manufacturing defect, and the key to having JBL replace them. If others don't have this issue, you definitely should not rest until JBL fixes them. (for free)
-Andy
Art Welter
« Reply #49 on: October 12, 2018, 02:48:55 pm »
Sounds like a guarantee for "no rest" ;^).
Pages: 1 ... 3 4 [5] 6 7   Go Up
Page created in 0.061 seconds with 23 queries.
