Author Topic: Sennheiser ew100 G3 handheld transmitter mute  (Read 33760 times)
Ray Aberle
    • Kelcema Audio
Re: Sennheiser ew100 G3 handheld transmitter mute
« Reply #10 on: December 24, 2018, 02:17:59 PM »
Did you ever solve the problem?  I have a ew100 G3 that just started doing the same thing.  How did you solve it?
It's possible, but as an aside, please note the Rules of Participation for the ProSoundWeb, wherein we do require that you post using your Real, Full Name. Aliases are not permitted for posting. Would you kindly pop back into your Profile and update your Display Name to reflect your Real, Full Name?
Thanks!
Ray
Kelcema Audio
Eric Wiebe
« Reply #11 on: December 24, 2018, 10:31:23 PM »
Replaced the capsule and it was all good again, much as I was expecting.
Jon Taccona
« Reply #12 on: February 03, 2023, 11:49:42 AM »
There is a 150K resistor inside the capsule that goes bad.  Mic works fine once it is replaced.  Just did 3 of them.
  • Old enough to know better
  • Audio Plumber
Posting Rules
« Reply #13 on: February 03, 2023, 11:57:40 AM »
Please go to your profile and change your name to your real full name as required by the posting rules.
admin
Dave Garoutte
  • San Rafael, CA
« Reply #14 on: February 03, 2023, 01:13:03 PM »
Thanks for the suggestions.  The mic wasn't even registering audio on the transmitter itself.  The transmitter also showed "Mute" on the small screen.
 As it is an install we do not scan each time we power up.  However, I did try that with no change.
I think I have narrowed it down to the capsule.  If I swap capsules with our other unit the issue follows this capsule, while the capsule from the other unit works just fine on this transmitter.
I posted a bit ago with this exact problem.  Sennheiser replaced the capsule.
jlklein
« Reply #15 on: September 03, 2023, 10:11:42 AM »
Hey Jon, good to know. I just had to replace 3 of these from Sennheiser (all the same lot #, ordered 8 of them at once years ago). Do you have any instructions on how to open the capsule and replace? I'm an eTech and figured it was something in the capsule's "mute me when the capsule is unscrewed" circuit that went bad but didn't want to damage the capsule. That said, Sennheiser did replace all 3 I sent in with brand new ones for $55 out of warranty repair, which ain't bad at all.
Thanks,
Jeff
--Jeff Klein, DMC-E
Head Volunteer Sound Geek
Faith Baptist Church
Glen Burnie, Maryland
http://www.faithbc.net / @FBC_TechTeam
http://www.reverbnation.com/7thvoice / @7thVoiceMusic
http://www.linkedin.com/pub/jeff-klein/32/852/6ba
http://www.vroc.org/view_profile.php?user_id=31526
"Clothe yourselves, all of you, with humility toward one another, for God opposes the proud but gives grace to the humble." 1 Peter 5:5
« Reply #16 on: September 03, 2023, 04:05:15 PM »
Thanks,
Jeff
Jeff, per the instructions when signing up you must provide your real name as the display name.   As soon as an OP sees it they will lock account.  Thank you.
Dave Garoutte
  • San Rafael, CA
« Reply #17 on: September 04, 2023, 02:45:17 AM »
I had a bad one and sent it to Senny for repair.  Turns out the problem was a bad capsule (which they replaced for their flat repair fee)! Not the switch.
If you have another capsule, try it.
Edit:  Oops, I guess I should have read up the thread a bit.
« Last Edit: September 04, 2023, 03:38:29 PM by Dave Garoutte »
Page created in 0.034 seconds with 19 queries.
