Author Topic: Red Rocks Amphitheater  (Read 2321 times)
Steve Payne
    • Soundworks of Virginia, Inc.
« on: August 15, 2018, 02:53:50 pm »
Went to Red Rocks last night as a punter to see the LSD tour.  First time to this incredible venue.  Sound was excellent.  PA was L'Acoustics.  Appeared to be 4 subs at the top with 8 K2 hung below per side, plus 4 more subs on the deck and 4 Arcs on top for near field, plus some frontfills.  Curious, does anyone know if this is a house installed rig or if tours have to haul in their own rig for every show?  Load in/out looks to be a doozy.
Steve Payne
like us on Facebook at:
https://www.facebook.com/SOUNDWORKSOFVIRGINIA
Steven Eudaly
  • Living the dream.
    • Headline Productions
Re: Red Rocks Amphitheater
« Reply #1 on: August 15, 2018, 02:57:38 pm »
The four "subs" at the top of each hang were very likely K1 tops, and not subs. I know getting to the top rows of the venue are tough to begin with, so I would be hard pressed to see a reason to further reduce your trim height by adding subs to the top of a hang.
AFAIK, PA is brought in on a per-show basis. Been seeing press on lots of shows there using either K1/K2 or d&b SL depending on the provider/show. Brown Note does a lot there.
Steve Payne
« Reply #2 on: August 15, 2018, 03:05:53 pm »
hmmm.  not familiar with what K1 looks like.  Top boxes appeared to be rectangular , however, K1 at the top would make sense.  I was puzzling over how in the world they were getting good vertical coverage on that steep of a rake with only 8 mid hi boxes aside.
Steve Payne
Steve Payne
« Reply #3 on: August 15, 2018, 06:54:58 pm »
Got the scoop from Steve Earle's FOH guy.  PA was Dwight's touring rig.
Steve Payne
« Reply #4 on: August 15, 2018, 07:22:05 pm »
K1 is rectangular with a vertical "V" notch in the middle; I think the subwoofer is the same size but flat (without the notch).
The profile of the K2 is trapezoid.
I've seen a fair number of touring rigs with 6-8 K1 on top, 4-8 K2 as under-hang, and K2 for side hangs.  It makes a LOT of sound.
John P. Farrell
« Reply #5 on: August 16, 2018, 12:32:28 am »
Last 2 times I've been there I had Clearwing supply the PA.  K1 over K2, which is a very common set up that does indeed produce a "lot of sound", lol.  Its a fun venue when the weather cooperates.
JF
FOH/PM Blackberry Smoke
Justin Segbers
« Reply #6 on: August 16, 2018, 07:52:21 am »
Truck dock is down the mountain a bit.  Semi's are unloaded there and gear is brought up on stake beds.
Its a painful in and out.
Don T. Williams
    • Q Systems Music & Sound
« Reply #7 on: August 16, 2018, 04:19:53 pm »
Still?  I thought they fixed that many years ago after I worked there (1980's).  And yes it was PITA.  I broke a rear end backing a 24' box truck up that winding ramp.
Steve Payne
« Reply #8 on: August 19, 2018, 08:29:08 am »
Ouch.
Steve Payne
John Sulek
  • Toronto Canada
« Reply #9 on: August 19, 2018, 09:16:46 am »
Load in/out still the same cross load deal but with a dock at the bottom.
Still rains every time around 3pm..lol.
Catering still awesome!!
