AFTER you have found a clear channel, the select you freqs and look at each one with a BW of 500kHc or a meg to really see if it is clear.
Thanks ... so the process would go like this then?:
1. Fire up WWB and load inventory (let's say 6 mics and 2 IEMs). Exclude known DTV channels per Shure's database and have WWB calculate frequencies.
2. Get list of frequencies and fire up Vantage ... check each frequency at baseline (all tx off) +/- 0.5mhz to verify they really are clear.
3. Turn on transmitters one by one and continue to check remaining frequencies.
Does that seem reasonable?
