Pages: 1 2 3 [4]   Go Down
Author Topic: DIY antenna stand question (that I can't find here)  (Read 2100 times)
Debbie Dunkley
  • Central North Carolina
Re: DIY antenna stand question (that I can't find here)
« Reply #30 on: August 07, 2018, 01:43:21 pm »
Just finished drilling two 1/2" holes in a K&M quad mic bar.
This was way to complicated for a simple piece, someone should offer this as an accessory, the demand would probably be in the low 100's. ;-)
Thanks Debbie and everyone else for the inspiration, perspiration and information, I'll report back with field testing this weekend. Antennas are 14" apart, should be enough as 1/2 a wavelength at 500 mhz is 11.23" and 9.36" for 600mhz.
https://drive.google.com/file/d/1w_ZCsodTnCg5ip5VpMA0FYjWZr8MLImU/view?usp=sharing
Good to hear Loren and U R welcome!...
I ought to thank you too because due to my response, it was pointed out by some members here that my antenna would work even better if placed farther apart.
Although I had never had any drop out issues with the use of the short mount and it had improved my RF connection raising the antenna up on a stand, I had never thought about separating out the antenna.  I based that thought on the fact that the antenna on the Shure receiver are about the same distance apart as they were on my dual mic mount so I figured that was good enough.
However, it makes sense and cost me nothing to make the change so now I have started to use the longer aluminum mount I showed here based on that advice.
Lyle Williams
« Reply #31 on: August 07, 2018, 06:17:08 pm »
In engineering, "perfect" is often the enemy of "good".  :-)
Any solution needs to balance technical concerns with practicality.  While you have a practical and proven solution I would stick to it.
It at some point your current setup isn't meeting your needs, some of the factors discussed may be useful in developing a new solution.
Pages: 1 2 3 [4]   Go Up
Page created in 0.048 seconds with 20 queries.
