Author Topic: Speaker Polarity  (Read 1341 times)
Re: Speaker Polarity
« Reply #10 on: June 09, 2018, 01:13:30 am »
Using heavy gauge Pig Hog brand cables which have hard plastic encased ends. Quality cable but I have to assume they are properly wired as the ends can not be opened to inspect.
An ohm meter and a couple of seconds will tell you if the cable is wired correctly
Michael Lawrence
« Reply #11 on: June 09, 2018, 12:11:33 pm »
You could also use free software such as Room EQ Wizard to run sine sweeps (or Smaart if you have it) , then overlay all the phase traces. I do this as part of a routine bench test, and also to check boxes before an install.
SynAudCon- Line Array Checkout
« Reply #12 on: June 09, 2018, 12:22:42 pm »
Probably overkill for the simple test the OP needs.
Michael Lawrence
« Reply #13 on: June 09, 2018, 06:27:19 pm »
Probably. Depends how many boxes there are, I suppose.
Stu McDoniel
  • Central Wisconsin...USA
« Reply #14 on: June 11, 2018, 10:53:34 am »
There are a few apps for android phones
JBL tools app has a polarity check
Polarity tester is another app
Youtube has pulses
Page created in 0.067 seconds with 22 queries.
