Author Topic: Speaker cable db / power loss  (Read 1282 times)
David Allred
« on: June 01, 2018, 02:46:21 pm »
Here is a good one for the really smart ones here.
Past threads have made reference to "Q: Why do we need such large cables (10 or 12 awg) for long runs when the wire inside most speaker cabinets is 16 or even 18 awg?  A: Because it is such a short length.  Capacitance or inductance, or some such."
The image shows the typical scenario above and a quasi-reverse scenario.  Are the losses the same for both?  The question arises from awg requirements in an amp rack between amps and patch panels, or even wire size (if wire used) in an amp itself
thanks.
Chris Grimshaw
  • Sheffield, UK
    • Grimshaw Audio
Re: Speaker cable db / power loss
« Reply #1 on: June 01, 2018, 03:20:26 pm »
The resistance of a cable is proportional to its length, and inversely proportional to its conductor area.
What that means is 1' of 1mm^2 copper has the same resistance as 10' of 10mm^2 copper.
From that, we can see that a cable that's 10x longer than the patch cables in the rack/cabinet will completely dominate the total cable resistance.
Chris
www.grimshawaudio.com
Art Welter
« Reply #2 on: June 01, 2018, 03:21:53 pm »
The losses are the same for both, the series wire resistance is the same, assuming the connectors have no resistance. Since the connectors do have resistance, the lower example with presumably an extra connector in the rack would have more series resistance.
The loss of power (a tiny fraction of a dB) is not nearly as noticeable as the loss of damping factor (DF).
With an amp with a DF of 500, 100' of 12AWG at 8 ohms drops the DF to 24.88, with a 4 ohm load the DF would drop to just 12.44.
DF below about 20 will tend to sound "floppy".
David Allred
« Reply #3 on: June 01, 2018, 04:39:45 pm »
Thanks
Len Zenith Jr
« Reply #4 on: June 01, 2018, 04:48:33 pm »
At the bottom of this link is a handy calculator for wire length:  http://www.bcae1.com/dampfact.htm
Helge A Bentsen
  • Oslo, Norway.
« Reply #5 on: June 02, 2018, 03:51:16 am »
One more reason to use Powersoft amps on subs/lows, they can compensate for cable losses below 400hz.
David Allred
« Reply #6 on: June 02, 2018, 11:42:11 am »
My subs are 8 ohm, though my tops on some setups are doubled to 4 ohms for coverage. Can I assume floppiness is only a concern for the subs?
Art Welter
« Reply #7 on: June 02, 2018, 01:28:52 pm »
"Floppiness" could also be considered "lack of definition", it applies to the upper cabinets as well as the subs.
One day on a corporate gig with plenty of extra time we experimented with a pair of 8 ohm center fill cabinets on a 40' wide stage, one had a 25' and the other a 75' 14AWG cord. We had noticed the longer cord cabinet seemed less loud (to be balanced, had to stand about  5' closer to it) so to confirm what the problem was, moved the cabinets next to each other to A/B cords and cabinets and amp sides.
The cabinets/cords/amp sides all read the same level with a dB meter, but to "sound the same", the longer cord cabinet needed to be 3dB louder, as verified by blind A/B tests with the three audio techs on the show.
Weogo Reed
  • Western NC,
    • LiveEdge
« Reply #8 on: June 02, 2018, 01:38:41 pm »
Hi David,
The 4 ohm load of the two nominal 8 ohm top boxes will need twice as much copper as the single 8 ohm sub.
Damping Factor is a measure of the amplifier/cable/speaker system to
accurately control the movement of a cone or diaphragm at low, mid or high frequencies.
For instance, with a really low DF, a cone that is supposed to move exactly in/out while tracking an
audio signal may 'wobble' a little bit at the farthest points of travel in and out.  This is heard as distortion.
You could try an experiment with a short, heavy cable feeding a box, and then a long, skinny one.
Note that really good speakers will more easily show DF differences than low quality boxes.
This will probably be most obvious when running the speakers pretty loud.
I generally design for a DF of 40+, but really, it's ok to go with what you hear.
(The Copper industry thanks me! )
Art, I've seen some pretty high dollar boxes that needed a db or two more than a
'perfectly' matched box from the same production run...
Thanks and good health,  Weogo
Art Welter
« Reply #9 on: June 02, 2018, 01:53:09 pm »
Yes, my first thought was we were hearing cabinet differences, but the A/B testing confirmed the differences we heard were due to damping factor.
Page created in 0.041 seconds with 24 queries.
