Pages: 1 [2] 3 4   Go Down
Author Topic: OK to position 2 x Apple Airport Express routers next to each other?  (Read 3468 times)
brian maddox
  • HeyYahWon! ttsss! ttsss!
Re: OK to position 2 x Apple Airport Express routers next to each other?
« Reply #10 on: April 10, 2018, 09:10:24 pm »
I appreciate that Scott. I will look into the Ubiquity WAP's ......
The Ubiquity stuff is quite good.  Especially when you start wanting to run multiple SSIDs and networks off of it.
brian maddox
bdmaudio@gmail.com
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
« Reply #11 on: April 10, 2018, 09:51:04 pm »
Though I think you guys are making it way too complicated. As soon as I heard vlans...
Come on guys, Debbie has a dozen or two fixtures. None are complicated movers needing a pile of DMX addresses.
Her IP network has 6 devices on it.
Everything except the tablets should have fixed IP addresses.
Debbie, IP addresses are just like postal addresses.
For class C networks (what most little networks are), try this analogy
 xxx.yyy.sss.zzz as an address
zzz is the house number
sss is the street name
yyy is the zip
xxx is the country code
DHCP assigns an address to me when I park my RV in your driveway. When I move on and park in Scottís driveway, the local DHCP servers gives me a new address local to him.
You already have one fixed address, the LAN port on your Airport Express. You also may have fixed (known as static) address in your QU.
All you need to do is assign fixed addresses to your DMX dongles then you can choose the right one for the tablet you are using.
The only thing you need be concerned about is to choose static IPs that are not in the group being handed out by the DHCP server in the AE. You can define which ones are handed out by using the Airport Utility.
Debbie Dunkley
  • Central North Carolina
« Reply #12 on: April 10, 2018, 10:23:23 pm »
yyy is the zip
yes Rob, my set up is pretty straightforward.
I have some confusion regarding this.
I have fixed IP addresses on my QU mixers but I have DHCP/Broadcast set on my two art net ODE's. If I were to assign fixed addresses to each of my artnet ODE's, how would the iPads that I use know which set of lights to control if both sets are connected to the same router? The iPad only distinguishes between router network names - doesn't it?.
« Reply #13 on: April 10, 2018, 10:40:17 pm »
yyy is the zip
Rob -
Her controllers use some type of broadcast protocol.  Can't have two in the same network.  That's why I suggested two SSID
frank kayser
« Reply #14 on: April 12, 2018, 04:59:52 pm »
Rob -
ARP/Unicast, I believe.  IP addresses are really irrelevant on my Enttec.
frank
« Reply #15 on: April 12, 2018, 05:26:51 pm »
frank
Frank - So two can live in the same collision domain?  The software has a way to map it to the right mac/controller?
frank kayser
« Reply #16 on: April 12, 2018, 11:09:42 pm »
Hi Scott,
I wish I could answer that definitively. I *think* so.  Enttec configuration software *can* identify the various Enttec controllers, but in Debbie's case, with multiple ODE manufacturers, I'd say the chances are slim.  Then again, it may be a plus. Above my pay grade.
My last attempt to get all that sorted was about nine months ago when the Unifi controller at the time was still having trouble with their unicast handling.  Also, I was just dealing with a single universe, and was running multiple VLANs, so I had a built in workaround just by adding another VLAN.  Since then, I haven't had the need or time to get back to it, unfortunately.
frank
James Paul
« Reply #17 on: April 16, 2018, 04:02:40 am »
Is there any reason why I should not place 2 Apple Airport Express routers next to each other.....
From the Apple APE set-up guide :
Best Locations for AirPort Express
The following recommendations can help your AirPort Express achieve the best wireless range
and network coverage.
     Place your AirPort Express in an open area where there are few obstructions, such as large
pieces of furniture or walls. Place it away from metallic surfaces.
     Avoid placing your AirPort Express behind furniture or inside cabinets.
     Donít lay your AirPort Express on its side. Donít place your AirPort Express in areas surrounded by metal surfaces on three or more sides.
     If you put your AirPort Express in an entertainment center with your stereo equipment,
donít surround AirPort Express with audio, video, or power cables. Place your AirPort Express
so the cables are to one side. Keep as much space as possible between AirPort Express and
the cables.
     Place your AirPort Express at least 25 feet (8 meters) from any microwave oven, 2.4 GHz
cordless phone, or other source of interference.
The following items can cause interference with Wi-Fi communication:
   Microwave ovens
   Direct Satellite Service (DSS) radio frequency leakage
   The original coaxial cable that may come with a satellite dish. Contact the device
manufacturer and get newer cables.
   Electrical devices such as power lines, electrical railroad tracks, and power stations.
   Cordless telephones that operate in the 2.4 GHz range. If you have problems with your
phone or AirPort communication, change the channel that your AirPort Express uses.
   Adjacent base stations using nearby channels. For example, if device A is set to channel
1, device B should be set to channel 6 or 11. For best results, use channel 1, 6, or 11 when
operating your device in the 2.4 GHz range.
    The farther away the interference source, the less likely it is to cause a problem.
_______________________________________________________________________________________
Though conventional wisdom would suggest best avoid direct stacked or adjacent placement, in practice (IME) though doable, not preferable. Best allow some distance of say a 24" or greater.
Another plus one for the Ubiquiti UniFi AP AC products, and fixed IPs for your digital mixers, and ARTNET/DMX dongles via ENNTEC and DMXking utility software, with DHCP for tablets and computers.
May I suggest a compact garden variety 4-6 port dualband B/G/N/AC wireless router, (2, redundant & power supplies), providing LAN ports your digi mixer, lighting dongles, and a DHCP-enabled PoE UniFi AP. With this setup, the XYZ WiFi Router would work for a majority of situations, whereas you can deploy the UniFi when required, as in larger distance access.
Debbie, questions. Why the separate lighting rig and hence dongle ? Why an APE ?
Debbie Dunkley
« Reply #18 on: April 16, 2018, 09:43:50 am »
the cables.
   Microwave ovens
Hi James , I am not separating lights from sound. I have run the 2 successfully for some years through one single Apple Airport Express router.
I am considering running another lighting universe which this current set -up (Luminair software) does not allow. I usually run this second light system by RF remote but it is awkward for me sometimes. So as I already own a second AE, it would be simple to run the second universe through that router and use a different Luminair program.
Update: As an experiment, on saturday I tried my 2 AE's stacked together and ran sound through one and lights through the other and it was successful.
However, I would still like to explore getting something like the Ubiquity that would allow the 2 networks through the one WAP.
James Paul
« Reply #19 on: April 16, 2018, 02:35:25 pm »
Debbie, no surprise with successful dual APE deployment. However my point is to reduce the use of two APEs, WAPs, or WiFi routers to only ONE active WAP for ONE network. To make use of what you already posses, one of your APEs, LAN to XYZ unmanaged switch or router, LAN to lamp dongles, LAN to digi-mixer du jour, resulting in ONE network, with TWO lighting universes, digi-mixer du jour, and any number of GUI devices, and a redundant APE.
¬ę Reply #19 on: April 16, 2018, 02:35:25 pm ¬Ľ
Pages: 1 [2] 3 4   Go Up
Page created in 0.044 seconds with 20 queries.
