Pages: [1] 2 3 4   Go Down
Author Topic: OK to position 2 x Apple Airport Express routers next to each other?  (Read 3465 times)
Debbie Dunkley
  • Central North Carolina
Is there any reason why I should not place 2 Apple Airport Express routers next to each other - using one to run sound remotely to QU mixer and also to run DMX stage lights - the other to run a separate set of DMX lights using different ODE and iPad.??.....
I have only ever used one router at a time so I've never had to consider this and I don't want to cause conflicts.
Thanks guys.
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
Re: OK to position 2 x Apple Airport Express routers next to each other?
« Reply #1 on: April 10, 2018, 02:55:41 pm »
My gut reaction is that yes they might mess each other up unless they explicitly are set up on different channels.
I would have em at least several inches separated.
« Reply #2 on: April 10, 2018, 02:57:55 pm »
Any reason you can't run on same network?
Sent from my VS995 using Tapatalk
TJ (Tom) Cornish
  • St. Paul, MN
« Reply #3 on: April 10, 2018, 02:58:12 pm »
Thanks guys.
That's not going to be a good situation.  Is there a reason you can't put your sound and lighting on the same wireless network?
Edit:  Beaten by Scott.
Debbie Dunkley
« Reply #4 on: April 10, 2018, 03:18:15 pm »
I have always run sound and lights through the same router using a switch.
However, I would like to be able to control a different set of lights in addition to this at certain shows from an iPad using the Luminair app which only has one universe. So I thought the easiest way to do this would be to completely separate the 2 systems so that 2 different Luminair apps could be used.
Both of my DMX ODE's  ( Enttec ODE and DMXking Pro 1) are set to DCHP right now but maybe if I issued a static IP address to each one, this might be a better way to solve the issue ???
As you all know - IP address assignment scares me - LOL !!
Jordan Wolf
« Reply #5 on: April 10, 2018, 04:21:45 pm »
You could use static IPs and set up your devices on different network segments (192.168.1.x for audio, 192.168.2.x for lighting 1, 192.168.3.x for lighting 2).
More work up-front, but if your setup is always the same, you now have known variables and can work around them if you add other devices.
Jordan Wolf
brian maddox
  • HeyYahWon! ttsss! ttsss!
« Reply #6 on: April 10, 2018, 06:10:22 pm »
I have recently ventured into the Very Scary World of Static IP networking on a fairly large scale.
Turns out it's a pretty cool world.  They have Cake!  True Story!
The only thing you have to fear is fear itself.  And device conflicts.  But whatever....
brian maddox
bdmaudio@gmail.com
« Reply #7 on: April 10, 2018, 06:41:50 pm »
I missed the cake was too mesmerized by the penguins on unicorns.
Seriously there is nothing to it Debbie and we have gotten you through this before.
However I would take this opportunity to upgrade to a pro grade WAP (Ubiquity UniFi) it supports multiple SSID's.  You will have to get a little managed switch too because it will deconstruct the virtual networks (one for each SSID) and map them to physical ports.
In fact if you get it you can just plug it all in and load Teamviewer on your computer.  I can login and set it all up for you.
brian maddox
« Reply #8 on: April 10, 2018, 09:03:05 pm »
Is that an open offer? :)
brian maddox
bdmaudio@gmail.com
Debbie Dunkley
« Reply #9 on: April 10, 2018, 09:07:13 pm »
I appreciate that Scott. I will look into the Ubiquity WAP's ......
Pages: [1] 2 3 4   Go Up
Page created in 0.082 seconds with 23 queries.
