Pages: 1 2 [3] 4 5 ... 10   Go Down
Author Topic: Combiner quality  (Read 10271 times)
Andrew Broughton
    • Check Check One Two
Re: Combiner quality
« Reply #20 on: April 16, 2018, 03:21:04 am »
Chris of RF Venue via email (I was asking questions) said their inputs are 100mw capable.
Not really sure what that means.
-Andy
Nathan Riddle
  • Niceville, FL
    • Nailed Productions
« Reply #21 on: April 16, 2018, 08:18:04 am »
It's not a listed spec on their spec sheet, so I figure when comparing the units with spec sheets that is a worthy addition.
Andrew Broughton
« Reply #22 on: April 16, 2018, 02:47:48 pm »
Gotcha, thanks!
-Andy
Don Boomer
    • RF Venue
« Reply #23 on: April 16, 2018, 08:52:13 pm »
Check again, it’s on the spec sheet😁
Don Boomer
RF Venue
Andrew Broughton
« Reply #24 on: April 17, 2018, 03:00:21 pm »
Other than the RF venue being 4ch and the others 8ch, it's MUCH less expensive (like 1/8th the price). I would love to know what specifically is different. No doubt an 8ch unit is more difficult to build than 4ch, but still?
-Andy
Nathan Riddle
  • Niceville, FL
« Reply #25 on: April 17, 2018, 03:17:54 pm »
Apologies  :-[ I could have sworn it wasn't  :o I should have double checked my memory with facts ;)
frank kayser
« Reply #26 on: April 18, 2018, 12:36:22 pm »
So all this discussion begs the question:
What specifically is (are) the problem(s) using a generic splitter/combiner if it covers the frequency range (350-1000mhz) and as a combiner, can handle the power input from the transmitters.
For example:
https://www.instockwireless.com/rf_power_divider_combiner_splitter/pd2581-datasheet.pdf
Other non-pro sound sites claim anything covering the TV range work - reliably enough for "A" level? No.  OK for bargain basement lounge use?  I know: risk vs reward.  Buy once, cry once.
frank
« Reply #27 on: April 18, 2018, 01:44:20 pm »
For example:
frank
The wide bandwidth does not provide for filtration.  You could add bandpass filters on the outputs but that would increase the cost.  The problem is that is after the internal amplifier.  You could also build a custom network of preselectors with the same caveat.
Lack of filtration on a wideband amplifier is just asking for intermod products.
River Delta Audio is now:
Jason Glass
    • CleanWirelessAudio.com
« Reply #28 on: April 18, 2018, 01:52:10 pm »
They also lack sufficient isolation between ports. Good wide band passives typically spec around 25dB.
Sent from my Nexus 5 using Tapatalk
Andrew Broughton
« Reply #29 on: April 18, 2018, 02:21:07 pm »
Again, I still don't understand how the 8ch devices are over $5k each and the 4-channel devices that are sub-$1k? The Sennheiser AC-3 and RF Venue Combine-4 are 6-8 times cheaper.
What are the "real-world" differences that justify the huge increase in cost?
If you're only using 4 channels, do they perform the same? If you use 2 of the 4-channel units for 8 channels with antennas spaced apart, does that work as well as a single 8ch?
« Last Edit: April 18, 2018, 02:24:14 pm by Andrew Broughton »
-Andy
Pages: 1 2 [3] 4 5 ... 10   Go Up
Page created in 0.081 seconds with 23 queries.
