Pages: [1] 2 3  All   Go Down
Author Topic: Avoiding intermod products based on anticipated strength?  (Read 3271 times)
Russell Ault
  • Edmonton, AB
« on: February 28, 2018, 05:22:18 pm »
This may seem like a strange question, but I'm wondering if there's a way to have WWB (or IAS, for that matter) factor the anticipated strength of intermodulation-produced signals into its suggestions?
For example, let's say I have a coordination that includes an unmodified BTR-800 base station running at high power (I know, I know) and two press-to-transmit beltpacks. I go to add a wireless microphone, and I ask WWB to avoid 2T3O and 2T5O intermodulation products. When WWB does the calculations, it will try to avoid all of the possible 2T3O and 2T5O products, despite the fact that the 2T5O products coming from the BTR-800 base station TX will likely be quite a bit stronger than any other paring's 2T3O. In reality, I can probably get away with avoiding the 2T5O coming only from the base station, and simply avoiding 2T3O is likely fine for the rest, so avoiding all possible 2T5O is spectrum inefficient.
Another, more complicated, example, would be the case of an actor wearing a primary and secondary microphone. In addition to wanting other microphones to avoid the 2T5O products from this pair of transmitters (since they're guaranteed to be too close together without any kind of isolation), it would be great to avoid 3T3O products from this pair plus all of the rest of the microphones in the zone. Of course I could try to avoid all 2T5O and 3T3O, but the likelihood of getting 30+ usable frequencies post-repack is basically nil.
Is there some way to do this with existing software?
Thanks!
-Russ
  • Old enough to know better
  • Audio Plumber
Re: Avoiding intermod products based on anticipated strength?
« Reply #1 on: February 28, 2018, 05:37:27 pm »
Thanks!
-Russ
In IAS it is easy to set turn on and off checking for any of the IM products. Turn off what you can get away with and do the bulk of your co-ord, then turn it back on and check against the mics you added to your list previously. The transmit from the BTR base should be kept as far from your mics as possible. An issue with this method will be that the BTR is you least frequency agile device, and you are adding to an already full spectrum. It is easy to do the BTR first and add your mics, but there is not much point in gaming the 5th order harmonics on the first device you add, there won't be many because there is only the BTR to check against.
John Sulek
  • Toronto Canada
« Reply #2 on: February 28, 2018, 05:50:24 pm »
Thanks!
-Russ
Not that I'm aware of, but there are many folks smarter than me here. You can always change the parameters as you work through your coordination.
You probably already know all this but here goes...
In the options tab of IAS, you can turn on/off the 2T30, 3T3O, 2T5O avoidance and also tell it to ignore 3 Tx intermods above a certain spacing which is adjustable.
You can change these options depending on what you feel will work in your situation.
I change these settings depending on which devices I'm coordinating with other devices.
I'm not as familiar with WWB, but there is a "compatability" tab beside the coordination workspace where you can change the intermod options for each device header (ie, all the psm1000's or all the BTR800)
Mac beat me to it.
Scott Helmke
« Reply #3 on: February 28, 2018, 06:25:45 pm »
I'm not sure how relevant this might be to your situation, but both IAS and WWB allow splitting things up into zones, with little or no intermod calculation between zones. I've used this feature sometimes on events like football games where all the gear is spaced out over a large area and I can make reasonable assumptions about what might get close to what.
Henry Cohen
  • Westchester Co., NY, USA
« Reply #4 on: February 28, 2018, 07:56:55 pm »
WWB does provide means to turn off the individual orders and number of TX's for each group of equipment. In the Frequency Coordination tab, populate the coordination workspace from inventory or a prior file. To the right of the workspace, select the tab "Compatibility" and turn xTyO on/off as desired/needed. You can break out individual devices by creating a new equipment profile and bring that into the inventory and then the workspace.
As for WWB, or any other IM program, attempting to calculate the signal strengths of the IM product(s), the answer is no. The software would have to have fields to input the signal strength values for every carrier, and that would add a tremendous amount of calculations and time. And what do you do about moving transmitters, where the signal level can vary by 10's of dB as the talent moves around?  If a carrier is within the RF space of concern, then any IM product, for which the carrier is a constituent, should be considered a potential interferer.
Henry Cohen
Russell Ault
  • Edmonton, AB
« Reply #5 on: February 28, 2018, 10:13:03 pm »
Thanks for the responses, everyone!
Correct me if I'm wrong, but my understanding of the Compatibility tab in WWB is that it allows you to select whether a particular type of device (or an inclusion group) should avoid the 2T5O (etc.) of all other transmitters in that zone; what I'm looking for is a way to make sure that all other transmitters in that zone avoid the 2T5O (etc.) of a particular subset of devices. The unmodified BTR-800 makes for a good example: I know it's going to throw serious 2T5O noise, so I want everything else to avoid its 2T5O, but not at the spectral expense of making everything else avoid all of each other's possible 2T5Os.
As for WWB, or any other IM program, attempting to calculate the signal strengths of the IM product(s), the answer is no. [...] If a carrier is within the RF space of concern, then any IM product, for which the carrier is a constituent, should be considered a potential interferer.
Understood; what I'm looking for is a way to deal with situations where I can reasonably assume that some IMD products are much more likely than others of the same order to be strong enough to cause interference. For example, I'm much less worried about the 2T5O from two ASMs with push-to-transmit beltpacks that stand 50' apart than I am about the 2T5O from the primary and backup 5212s straped 4" apart on the back of one of my leads. For a more complicated example, I'm a little worried about all 3T3O, but I'm particularly worried about the 3T3O produced by my double-packed lead having an intimate moment with her love interest. I'm not trying to predict the actual levels of IMD produced, which, as you say, are constantly in flux. What I'm looking for is a more granular way to indicate which sources of IMD interference I'm trying to avoid beyond "all possible 3T3O (etc.) in this zone".
I'm not sure about in IAS, but in WWB a device in one zone will not avoid the IMD products from devices in other zones (only their fundamental frequencies). Definitely useful, but not quite what I'm looking for here.
That's more along the lines of what I'm trying achieve. Not 2T5O mic-to-BTR, but just trying to avoid the BTR's 2T5O.
Thanks!
-Russ
Scott Helmke
« Reply #6 on: February 28, 2018, 11:15:50 pm »
For that matter, couldn't you create new equipment profiles with some of the intermod fields blank to selectively turn off certain calculations?
Russell Ault
  • Edmonton, AB
« Reply #7 on: February 28, 2018, 11:52:59 pm »
My understanding is that this would turn off those calculations when calculating the available frequencies for that equipment (i.e. same thing as adjusting settings in the Compatibility tab), not turning off those calculations when calculating available frequencies for other equipment (which is what I'm looking for).
-Russ
Paul McDermott
    • RF Coordination NYC
« Reply #8 on: March 01, 2018, 09:55:33 am »
-Russ
In IAS and WWB all devices are treated the same in the generation of IMDs and all devices in the same zone generate 2T3O 2T5O and 3T3O between devices of the same profile and between devices of other profiles. The only option is with each devise you can decide what IMDs you want to avoid. This method works very well when coordinating devices of the same type i.e. analogue wireless microphones. There are some issues with this rationale when you have types of devices that have IMD generation characteristics that are vastly different. I would put these in three main categories.
1. IEM and BTR TX
2. Analogue mics and belt packs
3. Digital mics and belt packs
When the devices are coordinated with other devices in the same category the software produces very reliable results But when you coordinate between categories you will have some issues. For example if you have 2T5O on for the calculation of your IEMs and BTR TX, when you calculate Axient Digital microphones with 2T5O off the will not avoid the 2T5O IMDs from the IEMs and BTR TX. Also to consider if you have 2T5O turned on when calculating other devices they will ovoid the 2T5O IMDs that the Digital microphones will most likely never generate.
WWB and IAS are calculators with very useful calculation features but have some limitations. Features that would allow the device profiles to determine if a devices produce 2T5O, 3T3O... wold be nice but is not available at this time and may be to confusing for some users. So use these powerful tools for what they are and we use work arounds for tasks they do not perform.
So lets look at what we can do for this BTR TX problem. I have a few solutions we should use as many methods to improve stability as possible.
1. In WWB use inclusion groups to segregate the BTR TX from other devices
2. put your BTR TX frequencies in tightly packed together using as little bandwidth as possible to minimize the impact of the IMDs on other devices
3.When posible put the BTR TX as close to an adjacent active TV station as possible or between 2 active TV stations. This will eliminate the impact many of the IMDs generated by this device
4. Use inclusion groups to keep analogue and digital microphones at least 10 MHz from the BTR TX frequencies
5. In a excel spreadsheet calculate all the IMD you want the other devices to avoid. Add these frequencies in a separate zone with a generic profile so they are treated as devices and not IMDs. (if anyone has a spreadsheet already made for this please share, if not I will share one when I get a chance)
I hope this helps and good luck.
« Last Edit: March 01, 2018, 02:40:04 pm by Paul McDermott »
Paul McDermott
937-478-5685
thunderpaul@me.com
http://rfcoordinationnyc.com
Jason Glass
    • CleanWirelessAudio.com
« Reply #9 on: March 01, 2018, 12:14:12 pm »
These are the methods that I use most, but I also create guard bands around likely IMD sources after assigning their freqs. In IAS it can be done by using the "edit active spectrum" function.
FWIW, this is why strict band planning can be so helpful.
Sent from my Nexus 5 using Tapatalk
« Last Edit: March 01, 2018, 07:54:35 pm by Jason Glass »
Pages: [1] 2 3  All   Go Up
Page created in 0.045 seconds with 23 queries.
