Author Topic: Help with processor settings: PRG Dual Aura 1808 box.  (Read 2481 times)
Tim Padrick
  • Indianapolis
    • T.P. Audio
« on: February 23, 2018, 12:18:54 am »
I can't get a call back from PRG, so here I am.
The impedance curve of the box is attached*.  The driver specs I've picked up from here and there over the years are: Nominal Z = 8, Re = 5.6.  FS = 25Hz.  Pe = 800W (800 continuous sine I believe).  Power compression is I believe 1dB at 56V, 2dB at 80V, 3dB @ 100V.  I need to set a high-pass and limiter (Rane RPM88 - attack time is in db/sec).
*4 Ohm power resistor in series with the 4 Ohm box, drive level set at each frequency for 4V across the resistor = 1 Ampere through the box.
Re: Help with processor settings: PRG Dual Aura 1808 box.
« Reply #1 on: February 23, 2018, 07:52:28 am »
The problem with saying "sine wave power", is that it can be very misleading.
At what freq was the sine wave applied?  A minimum point of actual impedance or the nominal impedance, or some other other freq?
How was the calculation done?  Using the actual impedance at that freq or a voltage at some freq and then using the nomimal rating?
Depending on how you do it, you could come up with different ratings when looking at "calculated watts".
I would start with a HP at the tuning freq (25Hz in this case).
The following is based on a "4 ohm rating".
Depending on the type of limiters available and type of musical style usage etc, you could have a thermal limiter at 28V 3 seconds or so up to a peak limiter at 112V.
56V being the continuous limiter setting.  25Hz 40ms attack time.
Tim Padrick
  • Indianapolis
    • T.P. Audio
« Reply #2 on: February 27, 2018, 07:36:41 pm »
Thanks Ivan.  (Some day I'm going to copy your desk idea - but with a Peavey Mark VIII.)
Understood on the knowing the true power handling.
Use is from mellow dance recitals to rock that's TFL - and I love the B string and 808 drops :-)
The limiter attack settings are not in ms but in dB/Sec.  Any idea how to correlate to two?  I can have multiple limiters in series, so if recommended I can have three at different level and time settings.  I just don't know what dB/sec gives me.
Page created in 0.062 seconds with 24 queries.
