Author Topic: When a Combiner goes bad...  (Read 3690 times)
Andrew Broughton
    • Check Check One Two
« on: February 14, 2018, 10:54:06 am »
1 P10T into PA821A
Good Combiner vs. Broken one...
-Andy
Scott Helmke
Re: When a Combiner goes bad...
« Reply #1 on: February 14, 2018, 11:48:05 am »
Wow, haven't seen that one before.  When I've had a bad PA821A it'll be one or more ports just not getting a full signal through.
Andrew Broughton
« Reply #2 on: February 14, 2018, 02:04:37 pm »
I'm very curious what goes wrong inside them that can cause this kind of grief.
-Andy
Henry Cohen
  • Westchester Co., NY, USA
« Reply #3 on: February 15, 2018, 09:49:28 am »
Presuming this is only one input channel, its amplifier stage is bad. probably overloaded at some point.
Henry Cohen
Andrew Broughton
« Reply #4 on: February 15, 2018, 08:49:17 pm »
Makes sense. Yes it was just one input.
It was tough to diagnose without a scanner.
Thanks, Henry.
Sent from my iPhone using Tapatalk Pro
-Andy
David Pedd
  • Gilbert, AZ
« Reply #5 on: February 15, 2018, 09:46:17 pm »
Went to a Shure seminar yesterday.  Great info.
The Shure man demonstrated how you overload the receiver front end by using the paddle antenna when you don't compensate for the db overload.
I'm guessing the same type of overload could fry the combiner.
Lyle Williams
« Reply #6 on: February 17, 2018, 07:20:53 am »
An attenuator is one of the most useful RF debugging tools you can own.
Andrew Broughton
« Reply #7 on: February 17, 2018, 11:03:47 am »
I'll bite... Could you elaborate?
-Andy
Henry Cohen
« Reply #8 on: February 17, 2018, 07:36:22 pm »
As a quick diagnostic tool to see if any part of your signal chain is being overloaded (with saturation of the subsequent gain stage) and causing problems which can appear as co-channel interference.
They are also indispensable when gain balancing a distributed antenna system.
Henry Cohen
Lyle Williams
« Reply #9 on: February 18, 2018, 07:09:01 am »
If you add (say) 6dB of attenuation and your problems drop by more than 6dB, something is operating outside it's linear operating range.
Page created in 0.05 seconds with 23 queries.
