Pages: 1 [2] 3  All   Go Down
Author Topic: Clogged fog heater  (Read 10470 times)
Rolando Saenz
Re: Clogged fog heater
« Reply #10 on: February 26, 2018, 10:07:54 AM »
CLR = Calcium Lime Rust remover. Typically found in any big box/grocery/hardware store here in the States.
https://clrbrands.com/Products/CLR-Household/CLR-Calcium-Lime-Rust-Remover
Thanks ;)
Keith Broughton
  • Toronto
« Reply #11 on: February 26, 2018, 11:36:33 AM »
You can also chuck a guitar string up into a drill and run it inside the tube. Sometimes that action will get it unplugged.
Great idea Tim!
Rich Grisier
  • Erie, PA
« Reply #12 on: November 19, 2018, 02:02:41 PM »
I picked up a couple used Chauvet RGB Geysers.  One has developed a clogged heater... oddly enough, this happened while I was running through a 50/50 Distilled Water/White Vinegar cleaning cycle.
I took the unit apart and verified there were no clogs leading up to the inlet of the heater. I also verified the pump was working.
I tried running a guitar string (tried E,  A and D) through the heater, but it appears the path takes a lot of twists and turns.  I ran the string into the inlet about 18" or so before I got scared of breaking it off inside the heater.  It never did make it all the way through.
I tried tried forcing air, water, and vinegar into the inlet with a squeeze bulb, but never got it to come out of the outlet.
So far, none of this has improved the situation.
The last thing for me to try (that I can think of) is what was mentioned here- to use CLR.  I pickup up some CLR, but it states on the bottle "Do not use on steam machines".  For those of you who have used CLR with success, have you had any problems? Is there anything else worth trying?
Tim Weaver
  • College Station, Texas
    • Daniela Weaver Photography
« Reply #13 on: November 19, 2018, 03:44:32 PM »
Just run distilled water through it after the CLR. You'll be fine.
The warning is for idiots who would put CLR in a steamer and try to huff it.
Rich Grisier
  • Erie, PA
« Reply #14 on: November 23, 2018, 12:33:56 PM »
Update: I've been trying to run CLR through it for 4 days. The most I can get through is about 1 drop a day. I have a syringe filled with CLR attached to the inlet. Pressure is being applied to the plunger to force liquid into the inlet. I've tried putting a tire pump on the inlet while applying 120 lbs of air pressure.  I can't feel the air coming out the other side.  I've tried the guitar string many times, but it eventually reaches a point where it just won't go any further.
I'm beginning to think this one is a lost cause and I should just get a new heater.
David Allred
« Reply #15 on: November 26, 2018, 10:27:36 AM »
Got any way to apply vacuum and draw cleaner backwards.
Dave Garoutte
  • San Rafael, CA
« Reply #16 on: November 26, 2018, 12:11:51 PM »
Or blow from the output end.
Rolando Saenz
« Reply #17 on: January 14, 2020, 07:53:56 PM »
so what happened
bought a new heater ?
or a new machine
David Allred
« Reply #18 on: January 14, 2020, 10:14:51 PM »
so what happened
or a new machine
I think I had a couple of fogger threads.  IIRC this one I got cleared by making a "hydraulic" pump with a brass fitting combo that would attach to the exit end and pushed the CLR through and the scale out.  So good results.  The other thread (fogger) I didn't have any luck.  Win some, lose some.
Rolando Saenz
« Reply #19 on: January 15, 2020, 10:34:25 AM »
I hear you man
Hey, is there somewhere that is your go to supplier of parts for foggers ?
Pages: 1 [2] 3  All   Go Up
Page created in 0.061 seconds with 24 queries.
