Author Topic: ASA1 with QLXD question  (Read 1563 times)
Keith Broughton
  • Toronto
« on: February 01, 2018, 05:50:27 AM »
The Sennheiser ASA1 antenna distro covers the RF range of the QLXD receivers I am considering. No problem there.
However, there is DC voltage on the coax that powers the Sennheiser receivers. I know that will not power the QLXD receivers.
The questions is, will it be a problem for the QLXD receivers to have DC on the antenna inputs?
The Shure UA844SWB is not all that expensive but it would be nice to use the distros I have available.
The same question applies with using the Shure IEm transmitters with the Sennheiser AC3 which has DC on the co-ax.
I would "imagine" there are DC blocking caps to protect the RF stage in both the Shure IEM and mic receivers but it's worth asking anyway.
« Last Edit: February 01, 2018, 08:05:23 AM by Keith Broughton »
Keith Broughton
  • Toronto
Re: ASA1 with QLXD question
« Reply #1 on: February 01, 2018, 08:07:00 AM »
Now I have had a coffee, I see the problem. :o
The mic receivers already have antenna bias voltage on them so using the Sennheiser antenna amp is a non starter!
The SHure antenna distro will be purchased.
However, the question still remains for the IEM transmitters to the Sennheiser combiner.
It's worth looking into as there are 2 of them in the IEM kit so money can be saved.
« Last Edit: February 01, 2018, 08:36:45 AM by Keith Broughton »
Adam Dumbacher
    • Bluewood Productions
« Reply #2 on: February 01, 2018, 09:30:56 AM »
RF Venue Distro 4 might be a good purchase for you. Ive been using them so I can use either brand of wireless. Their antennas are great as well.
Russell Ault
  • Edmonton, AB
« Reply #3 on: June 23, 2021, 09:20:43 PM »
I don't typically necro threads, but I was recently wondering something similar about the ASA 214 (the ASA 1's G4 replacement), and since this thread is one of the few useful search results for "QLXD ASA" I figured I'd add to the knowledge base here.
{...} The mic receivers already have antenna bias voltage on them so using the Sennheiser antenna amp is a non starter! {...}
I'm not sure I agree with this logic, for the same reason that connecting two consoles' inputs that both have phantom power turned on using a y-cable really shouldn't blow anything up. Either way, according to Shure, the QLXD4 doesn't supply bias voltage on its antenna inputs.
In the end, just to be certain, I contacted Shure support, and their response was "QLXD receivers have DC protection on the antenna inputs, you should be fine".
-Russ
Page created in 0.037 seconds with 19 queries.
