Author Topic: Trying to make my own antenna clamps.  (Read 3838 times)
Al Rettich
« on: January 17, 2018, 11:12:54 am »
I have quite a few wrap around clamps. The problem i'm finding is getting a 5/8" fine thread screw to go through the clamp into the antenna. Do any of you know of something that works?
Keith Broughton
  • Toronto
Re: Trying to make my own antenna clamps.
« Reply #1 on: January 17, 2018, 11:19:02 am »
I use pony clips and drill a 3/8 hole for a bolt to go into one of the 3/8 NC to 5/8 NF adapters that come with most mic clips.
Also have a "jamb nut" from a mic stand for the 5/8 side of the adapter.
Scott Helmke
« Reply #2 on: January 17, 2018, 12:23:49 pm »
Exactly what we do - got dozens of them.
Al Rettich
« Reply #3 on: January 17, 2018, 12:49:52 pm »
Done that as well. Sadly this is going up for a six month install around a 1 1/2" pipe. It's covered, but will still be outside. I know that the bolt I'm looking for is a tapered 5/8"-27 thread at most 2" long. Been hunting, with no luck.
Brian Bolly
  • Baltimore, MD / Amsterdam, NL
« Reply #4 on: January 17, 2018, 01:16:47 pm »
I've used these with some Mega Clamps.  I'm sure with some coupling nuts they could easily be adapted to Mega Couplers or similar.
Scott Helmke
« Reply #5 on: January 17, 2018, 01:38:41 pm »
How are you with a drill press and thread tap?
This is just an old lighting clamp, with some threaded 3/8"-16 rod and one of those adapters that came with a mic.
Chris Johnson [UK]
« Reply #6 on: January 18, 2018, 05:08:13 am »
Manfrotto Super Clamp (or magic arm for extra awesome).
'nuff said.
They aren't cheap, but they are the best.
Riedel Communications
Keith Broughton
  • Toronto
« Reply #7 on: January 18, 2018, 06:44:45 am »
Could you clarify what requires that type of bolt?
Do you mean a tapered head (flat head) and why so long?...no the install time ;)
Al Rettich
« Reply #8 on: January 18, 2018, 08:49:31 am »
To fit nicely inside the cheeseborough, it needs to be a tapered head, not a flat head. It's 1/2" through, I thought you could put a jam nut on it to lock it down in place, that would give you plenty of length. As far as the size of bolt, I've learned it's a 5/8" - 27. 5/8" isn't hard to find, but the 27 threads per inch is.
Scott Helmke
« Reply #9 on: January 18, 2018, 10:02:43 am »
OK, helps to know the specific clamp you were talking about.
I really don't think you're going to just find a 5/8-27 bolt. It would almost certainly be cheaper to modify the cheeseborough to accept a 3/8-16 thread and adapt from there. Add a safety cable and you've got a solution.
Even if you're set on a nice-looking solution it would be cheaper to have a machinist make an adapter than to have that same machinist make a bolt with a weird thread.
Page created in 0.053 seconds with 24 queries.
