Author Topic: Multi-voltage Distro  (Read 4051 times)
Pierre Foster
« on: December 27, 2017, 11:41:27 pm »
I have searched high and low for a Distro (preferably rack mount) that meets my needs but I am starting to think that what I seek does not meet code so it isn't offered.
The input of the Distro is not as important as the output but generally I use 50a CS from generators. My problem is that I need a mix of 120v and 240v outlets as my amplifiers are all 240v but other rack equipment is 120v.
If this configuration is against code then I understand completely but if not can someone point in the right direction if such a distro exists.
Mark Cadwallader
  • Helena, Montana USA
Re: Multi-voltage Distro
« Reply #1 on: December 28, 2017, 02:02:00 am »
Yes, you can get distro assemblies with both 240v and 120v recepticles. Motion Labs is one reliable brand; Indu-Electric is another. Both make listed, code compliant devices. Whether or not they have a standard model that meets your needs is another question. You might need a custom panel to give you what you want.
Pierre Foster
« Reply #2 on: December 28, 2017, 09:50:04 am »
Thanks for that info Mark glad to know I'm not in search of some mythical creature. I did also find a company after my initial post called Entertainment metals that seems to sell all the components to build my own rac pac. I know the first concern will be the fact it isn't UL listed however I am in the Cayman Islands and while we do have electrical inspectors I would be fine with one of these self built racpac's
« Reply #3 on: December 28, 2017, 11:11:01 am »
IIRC, *assemblies* from Entertainment Metals are UL Listed.  I suggest a phone call to them if Listing is a requirement down in the Islands.
Ray Aberle
    • Kelcema Audio
« Reply #4 on: December 28, 2017, 11:18:29 am »
I did a generator rental recently where the electrical inspector was satisfied just based on the distro being UL-listed. Never mind the "Indoor Use Only" printed right next to the UL-Listed mark, and we were outside, in between rain showers.... haha. Oh well. Didn't notice, or didn't care.
As alluded to, "UL-Listed" =/= "Code Compliant." Your AHJ may have certain expectations that, if you don't meet, will end poorly.
As for ML, WhirlWind, EMG, etc- for an assembly to be UL listed, they have to submit the overall design of (the distro, rackpack, etc) to the UL people for certification. So, they're less apt to do truly custom work (as in a RackPack that takes a special connector in or creates a special mix of outputs, beyond what they already have publicized on their website), since the UL-certification would be cost prohibitive for a one-off or limited production run item.
So, it depends on the style of connector you need for the 240V connection. You may also find it easier to purchase an off-the-shelf unit and just swap out the one connector you need to change. (I know many people with typical "construction" spider boxes will swap the L6-30 out for an L14-30, since in this area, AV peeps CAN use L14-30 but probably CANNOT use L6-30.)
-Ray
Kelcema Audio
Pierre Foster
« Reply #5 on: December 28, 2017, 11:50:07 am »
Thanks Tim, listing is not a requirement however I do still want to be safe. I have sent them an email so let's see if they respond.
Pierre Foster
« Reply #6 on: December 28, 2017, 11:55:13 am »
-Ray
Thanks Ray, I definitely understand why companies would be reluctant to stray away from their off the shelf designs. What I need isn't very complicated and there are man industrial spider boxes out there that offer what I want. I'm just having a hard time finding it in a rack mounted version.
Henry Cohen
  • Westchester Co., NY, USA
« Reply #7 on: December 28, 2017, 12:27:53 pm »
Motion Labs RaC Pac
Whirlwind catalog, page 7.
Lex Products
Henry Cohen
Mark Cadwallader
« Reply #8 on: December 29, 2017, 01:34:39 pm »
Pierre, depending on the exact configuration you need, you might consider two panels: the first for 240v, and a second with 120v, both using a CS 50A in and thru so they can be "daisy chained" together.  That "off the shelf" combo might be cost-effective, especially if you want to use fully listed assemblies in a rack mount format.
As an example, you can look to see how 200A 3-phase distos mix and match panels to provide a mix of recepticles. Your solution would omit the 3-phase feeder panel, of course.
Pierre Foster
« Reply #9 on: December 30, 2017, 09:06:59 pm »
Thanks for this Mark, I think you fully understand what I am trying to achieve. None of the companies listed previously offer a single rack mount unit that accepts a 50a cs and has a mix of 120v and 240v outlets. Purchasing one of each may be the only way to go.
Page created in 0.043 seconds with 23 queries.
