Author Topic: True1 safety notice  (Read 3782 times)
John Fruits
True1 safety notice
« on: December 21, 2017, 06:52:17 pm »
I just saw this posted by Steve Terry of ETC at another forum.
True1
The link to the safety notice is on the right hand side of the page.
It seems that the powerCon connectors don't suffer from this issue.
The True1 is becoming more prevalent for lighting (especially IP rated fixtures).
"The music business is a cruel and shallow money trench, a long plastic hallway where thieves and pimps run free, and good men die like dogs.  There's also a negative side."-Hunter S. Thompson
ThomasA(lbenberger)
Re: True1 safety notice
« Reply #1 on: December 22, 2017, 03:29:18 am »
True1
Hi John!
What exactly is it you are showing us here?
What I gather from this safety notice is: Take care while plugging in the connector and you'll be fine.
Anything else?
Best Regards, Thomas
Erik Jerde
« Reply #2 on: December 22, 2017, 10:26:49 am »
Rough copy/paste from the notice.  Pics didn't come through of course.
powerCON® TRUE1
Please regularly check the condition of your powerCON TRUE1 connector system (cable connector
& chassis) for clear signs of wear and tear.
Through improper use and the excessive use of force, the encoding lugs and guide slots in the connector system can become so severely worn or damaged that it is possible to insert the cable connector the wrong way. However, when inserted the wrong way, the cable connector should not twist-lock into place.
A cable connector inserted the wrong way could, in some circumstances, lead to contact between live wires and the grounding contact in the plug socket.
To determine that the cable connector is inserted correctly, follow the use instructions and listen for the “click” when performing the twist-lock. Immediately unplug any connector that does not twist- lock correctly in place.
          ABC
               Note: When connecting, match the notch on the cable connector to the corresponding guide slot on the chassis.
Note: After inserting properly as in illustration A , twist the cable connector clockwise to lock.
click
Note: The proper twist-lock is achieved when the yellow tab is in the position shown in C and an audibel «click» is heard.
      SAFETY WARNING
incorrect insertion may cause electrical contact misalignment resulting in equipment malfunction and/or personal injury.
max.
1 Newton
John Fruits
« Reply #3 on: December 22, 2017, 11:16:34 am »
Hi John!
Anything else?
For me the main takeaway is that what should be a foolproof device might develop issues.  For most people this is would not be a problem.  In a perfect world all the crew would know what they were doing.  In the real world you sometimes end up with the doofus who is of the "ram it, jam it, get'er done" school.  Therein lies the rub.
Mark Cadwallader
  • Helena, Montana USA
« Reply #4 on: December 22, 2017, 12:34:10 pm »
That's shocking!
Riley Casey
« Reply #5 on: December 22, 2017, 12:37:08 pm »
Long standing problem on NL4 connectors in long service.  A big reason why I've looked askance at Neutrick for AC power connections beyond rack gear that isn't mated regularly or by freelance crews.
Frank DeWitt
    • LBP DI Box
« Reply #6 on: December 23, 2017, 09:22:25 am »
The problem with making things fool proof is that fools are so darn clever.
Not to Code
Tom Bourke
    • http://www.cwalv.com
« Reply #7 on: December 23, 2017, 09:26:00 am »
I prefer the term idiot resistant.  But then they keep making better idiots!
Daniel Levi
« Reply #8 on: December 23, 2017, 01:44:39 pm »
https://www.youtube.com/watch?v=vhJmEGs7P2E
Lyle Williams
« Reply #9 on: December 24, 2017, 07:02:51 pm »
In terms of elegance, these entertainment-specific power connectors are more "SCART" than "HDMI".
Page created in 0.086 seconds with 22 queries.
