Mark;
Check to see if the clip light is Post Bus Master Fader. I know I normally have 3 stereo Buses setup for my mixing. 1 for vocal's , 1 for guitars and 1 for the drums set to stereo. As I add channels to each Bus I bring the Bus master down some. I can run each Channel at -18dbu and run the channel fader around +/- 6db and have set the Bus master down with no clip indicators. Seems to be 1 channel going to a Bus I can have the Bus master at 0. 2 channels Bus master to neg 6. 4 channels sent to a bus the Bus master to -12 etc. ( all aprox ) . I've been doing this for some time and it seems to work well for me.
A good link to watch.
https://www.youtube.com/watch?v=khBHcfyI5e8&t=27s
Picture is of my general starting point of my Bus Masters.
Douglas R. Allen
Thx guys,
I feel very comfortable with gain structure, and how channels can sum to higher levels.
(Watched the two Scovill classes to hear his takes on analog emulation...very interesting).
Here's the simplest test I've found to check out DCA clipping.
Oscillator to Mixbus 1; Mixbus 1 to Output 1; Scope on Output 1.
DCA1 assigned to Mixbus 1. DCA meter reads Mixbus1 output as set by bus master, at all times.
DCA meter does not vary with DCA fader level, nor does a DCA solo vary.
Sine from oscillator set at -3dB. Mixbus1 master at 0, DCA fader at 0. All good. Mixbus1 meter, DCA strip meter (and solo) all in sync at -3dB.
Raise Mixbus1 master, DCA meter shows clipping. Scope shows clipping. Good! preventable by DCA meter observation.
Leave Mixbus1 master at 0, raise DCA fader observing no change on DCA meter. Scope shows clipping. Bad!
Not preventable by any meter observation unless Mixbus 1 is routed to a Main or matrix output for observation there.
I guess the moral or the story is i need to be more careful with Mixbuses and DCA's going straight to outputs.
I was getting along fine with this for years, using only a single DCA per Mixbus. Like you guys were saying, no audible worries.
I think when i went to 2 DCA's per mixbus, their compounding effect pushed me into audible clipping.
