Pages: 1 2 [3] 4   Go Down
Author Topic: 5 Megawatt Load Bank  (Read 7906 times)
Chris Hindle
Re: 5 Megawatt Load Bank
« Reply #20 on: November 20, 2017, 08:17:32 am »
So next time you see a "DANGER HIGH VOLTAGE" sign on a door, chances are, it isn't really.
Maybe not, but it will still kill you in a flash.
Don't take ANY voltage lightly.
Chris.
Nathan Riddle
  • Niceville, FL
    • Nailed Productions
« Reply #21 on: November 20, 2017, 01:57:48 pm »
I just found the ANSI definitions. So 99.9 kV is considered "Medium" voltage. Holy crap...
Voltage classes: (ANSI C84.1-2016)
Low Voltage: 1000 volts or less
Medium Voltage: greater than 1000 volts and less than 100 kV
High Voltage: greater than 100 kV and equal to or less than 230 kV
Extra-High Voltage: greater than 230 kV but less than 1000 kV
Ultra-High Voltage: equal to or greater than 1000 kV
Following the convention (Orders of Magnitude) then:
Extra-Low Voltage: greater than 1mV and less than 1V
Ultra-Low Voltage: greater than 1uV and less than 1mV
 :D
Mike Sokol
« Reply #22 on: November 21, 2017, 09:23:02 am »
 :D
Are those dangerous voltages as well?  ;D
Mike Sokol
mike@noshockzone.org
www.NoShockZone.org
Jonathan Johnson
« Reply #23 on: November 21, 2017, 05:07:03 pm »
I was looking around for a surplus load bank for some of my experiments and I came upon this semi-trailer version. Now the picture says 5 mW which I always thought a lower case "m" denoted milliwatts, but I'm pretty sure this is a 5 MegaWatt load bank as in 5 million or 5,000,000 watts. I don't know why, but I really want one of these... ;D
I've been looking at getting a table saw -- a stationary "cabinet" style saw, at least 3 HP. I don't have a lot of money to spare, so I'm looking at used saws. It seems that 3 phase saws come up on the C-list fairly often at pretty reasonable prices, but I don't have 3 phase power available. That's probably why they come up cheap -- hard to sell 3 phase machines.
(Well, I probably could put 3 phase power in if the utility didn't charge more than my annual salary to put in a transformer bank, plus charging me commercial rates -- the lines come right into the yard less than a hundred feet from my workshop.)
But then I realized that for the right deal, I could get a VFD (variable frequency drive) for a three-phase saw. More efficient than a rotary or solid state phase converter, and available for single phase supply. The VFD plus the 3-phase saw might end up costing less than a single phase saw.
Anyway, to bring this back to the original topic, the VFD supports the installation of a load bank for dynamic braking. Mike's load bank might be a wee bit of overkill, but hey, you could probably stop that saw nearly instantly with that kind of sink!
(Or maybe not.)
« Last Edit: November 21, 2017, 05:09:34 pm by Jonathan Johnson »
  • Old enough to know better
  • Audio Plumber
« Reply #24 on: November 21, 2017, 06:09:15 pm »
Or you could spend the really big bucks and get a SawStop!
Mike Sokol
« Reply #25 on: November 21, 2017, 06:10:37 pm »
(Or maybe not.)
This is a great example of how to get a topic swerve back on point... ;)
Mike Sokol
www.NoShockZone.org
TJ (Tom) Cornish
  • St. Paul, MN
« Reply #26 on: November 21, 2017, 07:46:03 pm »
(Or maybe not.)
if this load bank is designed for a couple thousand volts, it may have a fairly high impedance, meaning it might not work so well at 208 volts.
Mike Sokol
« Reply #27 on: November 21, 2017, 08:00:39 pm »
If we knew what voltage it was we could easily calculate the impedance for 5 megawatts of load. I gave that on a quiz today for my audio electronics students. So what voltage shall we assume it needs for the full 5MW?
Mike Sokol
www.NoShockZone.org
TJ (Tom) Cornish
  • St. Paul, MN
« Reply #28 on: November 21, 2017, 08:54:34 pm »
Well, based on your chart, my calculations show 0.2Ω for 1001V, 20Ω for a 10KV voltage up to about 2000Ω for a 99KV input voltage.  A 2KΩ load won't be a great brake for your VFD at 240 volts - that's only about 30 watts.  If it's 0.2Ω, that would definitely be an effective brake.
Geert Friedhof
« Reply #29 on: December 19, 2017, 09:47:49 am »
Pages: 1 2 [3] 4   Go Up
Page created in 0.063 seconds with 22 queries.
