Pages: 1 [2] 3   Go Down
Author Topic: Nuendo Live Rec Tracks Not Lined Up  (Read 4284 times)
Chris Trupe
Re: Nuendo Live Rec Tracks Not Lined Up
« Reply #10 on: November 11, 2017, 02:48:10 pm »
So, some more info.
The files start at the same place.
Audio does not.
The ends of my files are all different.
If I line up the ends of all my files, the audio all lines up.
I have yet to have a chance to try another program to record into.
Chris Trupe
« Reply #11 on: November 11, 2017, 02:49:10 pm »
Not something I've seen on Nuendo Live with Yamaha boards via Dante so probably in the getting to the laptop part of the universe but you probably already suspect that.  Any pattern to which tracks are offset ?  Any track count below which it stops happening?
Groups of 4 or 5 for the most part.
Chris Trupe
« Reply #12 on: November 11, 2017, 02:50:16 pm »
It happens with Yamaha boards via Dante too. I haven't  figured pattern, but what happens is that some tracks are not being recorded at the same time with other tracks. It means that recording of  the tracks in question starts later than other tracks(i.e. one second or maybe less later). When the recording is stoped software, for some reason aligns the tracks to the begining of the time line, but if I look at the end of the session, I can see that the duration of of some tracks differs from others.  The solution is simple, you just align the  tracks so that they end at same time...
Sent from my Redmi Note 4X using Tapatalk
Yes, this does work, really sucks that the live version does not have the snap feature, or at least not that I have found.
boburtz
  • San Francisco Bay Area
    • SoundWizard Productions
« Reply #13 on: November 11, 2017, 07:26:55 pm »
Nuendo live has a feature  whereby it is always recording to ram for the "pre-record" function. The way this is staggered it looks like a ram issue to me. Like it is printing the recording in a sequential manner, as though it is filling the ram buffer prior to printing each set of tracks. Have you tried playing with the pre-record settings?
Chris Trupe
« Reply #14 on: November 11, 2017, 07:35:16 pm »
I have had the same result with the pre record set at 10s and also at 0s.
10s is the stock Nuendo setting.
Justice C. Bigler
  • Somewhere between the Atlantic and Pacific
    • My homepage
« Reply #15 on: November 11, 2017, 09:54:17 pm »
Refresh my memory. Does Nuendo Live allow you to use ASIO audio interfaces? And if so, can you try recording through a separate interface, taking DVS out of the picture to see if this is a Nuendo issue or a DVS issue?
Justice C. Bigler
www.justicebigler.com
Head Audio/A1 Blue Man Group North American Tour
Chris Trupe
« Reply #16 on: November 11, 2017, 10:00:25 pm »
I am not using Dante.  Digigrid MGB and Soundgrid.
John Ferreira
« Reply #17 on: November 14, 2017, 02:26:46 am »
Chris do you still have the same problem if you increase the buffer size to 256 or 512?
John Ferreira
Chris Trupe
« Reply #18 on: November 14, 2017, 09:15:19 pm »
Even maxed out the buffer and still the same issue.
Mark Rombouts
« Reply #19 on: November 15, 2017, 09:37:18 am »
I never had an issue like this with Digico or Yamaha combined with UB madi, or DVS or Soundgrid. I always use Protools or Waves Tracks Live.
I would suspect Nuendo.
Pages: 1 [2] 3   Go Up
Page created in 0.075 seconds with 22 queries.
