Pages: 1 ... 38 39 [40] 41   Go Down
Author Topic: New Allen & Heath SQ Series  (Read 97507 times)
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
Re: New Allen & Heath SQ Series
« Reply #390 on: January 25, 2019, 02:12:08 pm »
I think a dx4816 is coming first (hopefully with ME expander ports)
That image was taken down so I doubt this is (supposed to be) public knowledge.
And like all the other releases the update page wasn't updated until the firmware was actually released.
I'm thinking late March into April.
Also, that slide could be faked...
Or it was a dealer meeting and to be announced soonish?
Nathan Riddle
  • Niceville, FL
    • Nailed Productions
« Reply #391 on: January 25, 2019, 02:42:30 pm »
No idea, the image looks like some meeting at NAMM.
I stole it from a user group on FB.
I didn't sign any NDA's  :P
I cannot wait for MBC, DynEQ, DeEsser plugins! :)
Nathan Riddle
  • Niceville, FL
« Reply #392 on: January 25, 2019, 10:14:58 pm »
Nathan, why this first?  Inside knowledge?  Or just thinking that this would be the most “complete” stage box connected to a FOH SQ?
Saw it on the post where the image came from.
So it's mostly speculation and 3rd hand info. But it also makes sense imo.
Scott Bolt
« Reply #393 on: January 26, 2019, 04:36:18 pm »
I don't own an SQ, but I would certainly like one ;)
Just one man's opinion, but I think that an off-line editor is an expected feature of any new digital mixer today.  For the SQ level of mixer I would think it was a glaring omission in today's market.
Jeff Lelko
  • Cape Canaveral, FL
« Reply #394 on: January 26, 2019, 04:59:52 pm »
Didn’t really expect what I’d really like to see, an SQ level equivalent of Qu-SB or Qu-Pac.
I too am quite surprised that there's no "SQ-Pac" yet.  I would have guessed we'd see one of those before the SQ7, but that's apparently not in line with what A&H has planned for this series.  The Qu-Pac is now 4 years old, and while not ancient by any means I'd think A&H would want to push as many users as possible up to an SQ equivalent with added features, especially if they plan on SQ eclipsing Qu.
Rob Spence
« Reply #395 on: January 26, 2019, 09:53:52 pm »
Adding the SQ7 to manufacturing was a pretty easy change for the production line. All 3 SQ desks can be made on the same line.
A rack box is a new line to start up. Takes longer.
Nathan Riddle
  • Niceville, FL
« Reply #396 on: May 29, 2019, 08:09:59 am »
A&H SQ V1.4 Firmware updated
Major improvements:
-Offline editor (iPad, Android, PC, Mac)
-Ganging
-Rack FX Plugins (add-ons) [MBC, DynEQ, DeEss]
-Recall Filter
-Mono Matrix
-Midi protocol implementation
https://www.allen-heath.com/sq-v1-4/
https://www.allen-heath.com/media/Release-Notes-SQ-V1.4.0.pdf
https://www.allen-heath.com/media/SQ_ReferenceGuide_V1_4_0.pdf
https://www.allen-heath.com/media/SQ-MIDI-Protocol-Issue1.pdf
V1.4.0
Additional Features:
New add-ons available: DeEsser, Multiband Compressors (MultiBD3/MultiBD4), Dynamic EQ (DynEQ4)
Ganging
Per-scene recall filters
USB Scene and Library archiving
Copy Paste Reset of Scenes and Per-scene recall filters
IO Page socket control
Sync Mode for SQ-MixPad connection
MIDI NRPN control of Levels, Panning/Balance, Mutes, Assignments, SoftKeys
Mono matrix option
Preamp on surface option
Processing screen follows surface option
PEQ band follows screen option
Name/Colour options in channel library
HPF option in PEQ library
New soft control additions – MIDI program changes, note on/off, Listen Level
SQ-MixPad additions – Offline mode, follow SQ channel/mix options, PAFL setup, channel routing screen
Support for DX32 modular expander added
Global recall filters re-organised and extended
SQ-Drive performance metering
RTA peak band indication in GEQ Fader Flip
Socket number displays on channel LCD display
Channel and strip numbers added to strip assign
Touch scrolling added to all on-screen lists
Improvements:
ID-1201: Channel ms delay control improved
ID-1227: Compressor parallel path Dry/Wet control improved
ID-819: Channel mute time when engaging/disengaging PAD reduced
ID-620: Fader calibration process no longer requires rebooting
SQ Release Notes V1.4.0 Page 3 of 5
Issues fixed:
ID-720: Removed persistent metering when dSnake unit is disconnected
ID-1008: Mixer shutdown gracefully closes SQ-Drive recording
ID-1149: Reset Mix Settings button blocked correctly using user permissions
ID-1044: Input patch filtered when preamp recall blocked
ID-1266: SQ-Drive seek bar appears correctly on first launch of screen
ID-1276: SQ-Drive recording to maximum length no longer lists two recordings in playback
ID-565: Stereo insert left disconnects correctly when right send is repatched elsewhere
ID-1390: Corrected issue with incorrect output patching when switching mix stereo/mono
ID-894: Insert LED correctly displays status on scene recall
ID-807: FX Library items now contain Dry/Wet levels when stored as insert
ID-563: Insert point In/Out status persists when creating or editing
ID-1307: Correction to stereo flag when sending mix channels to a ME system
ID-364: Preamp surface control does not affect trim when Mix Ext In has no preamp available
ID-1339: AR84 Tie Line patching now persistent after power cycle
ID-1271: Routing screen now displays from LHS on opening
ID-1287: Fixed inconsistency in AFL/PFL on LR when switching output AFL setting
« Last Edit: May 30, 2019, 10:12:21 am by Nathan Riddle »
Roland Clarke
« Reply #397 on: May 30, 2019, 05:51:53 am »
That’s more like it!  Looks like the SQ is getting to offer some good value.
Peter Morris
« Reply #398 on: May 30, 2019, 07:54:27 am »
Dan Richardson
  • southern Vermont
    • NotTooLoud
« Reply #399 on: May 30, 2019, 09:22:12 am »
Major improvements:
-DEEP Plugins (MBC, DynEQ, DeEss)
Rack, not DEEP.
The best sound system is no sound system. Everything else is compromise.
Pages: 1 ... 38 39 [40] 41   Go Up
