Pages: [1] 2 3  All   Go Down
Author Topic: Wireless distribution of line level audio to remote speakers  (Read 3823 times)
Mal Brown
« on: October 21, 2017, 06:07:49 pm »
I'll be purchasing this off season, would like to be able to transmit 2 channels.  Clearly the new FCC Regs regarding the 600 MHz band are a consideration.  Any vendor I buy from will have to answer that...  Investment level is a factor but quality is as well...  What are the options and trade offs?
Bass player, sound guy.
Fb Gorge Sound and Light
WillyandNelson.com
Jerome Malsack
Re: Wireless distribution of line level audio to remote speakers
« Reply #1 on: October 21, 2017, 06:28:58 pm »
Most people would work this as a pair of IEM receivers with a stereo Transmitter.  Then make you cable for the receivers to the powered speakers.
You can pick the usual IEM providers, shure, sennheiser, audio technical, to name a few.
Mal Brown
« Reply #2 on: October 21, 2017, 08:14:10 pm »
Are there good, better, best amongst the iem systems ?
WillyandNelson.com
Dan Currie
« Reply #3 on: October 22, 2017, 12:30:16 am »
How far are you looking at transmitting?  Mono? Stereo?  More info on what you are trying to do with details will help.
Mal Brown
« Reply #4 on: October 22, 2017, 07:23:59 am »
 I'm guessing  150 to 200 feet ...  maybe 300 at the limit. 2 channels a spec' above.could be stereo, could be dual mono.  Most often dual Mono.
WillyandNelson.com
Don T. Williams
    • Q Systems Music & Sound
« Reply #5 on: October 22, 2017, 05:58:09 pm »
The Alto Stealth system is designed for this very purpose.  I've used it successfully to about 200' distance outdoors, but only a few times.  The Neutrik XIRIUM PRO system is also designed for this purpose and has a much longer range . . . and much higher price!
Henry Cohen
  • Westchester Co., NY, USA
« Reply #6 on: October 22, 2017, 09:05:54 pm »
If your distance is only 300', and unless there are extenuating circumstances (going across a river or deep ravine, significant crowds with no safe cable path), you'll be far better off running two balanced pairs; it'll be less expensive and almost always far more reliable.
That said, if the feed is critical, using higher end equipment will provide the level of performance and reliability needed:
Lectrosonics IFBT-4 transmitters (in 400 series mode) along with any 400 series receivers; or
Shure PSM900 or 1000 in PtP mode and UHF-R receiver (or Axient set to UHF-R mode).
Use an appropriate antenna (omni or directional) for the TX, and passive high gain directionals for the RX, along with low loss coax.
Henry Cohen
Ray Aberle
    • Kelcema Audio
« Reply #7 on: October 23, 2017, 12:44:48 am »
Mal, when I get back from Wisconsin, let's meet up with gear and play around a bit- I'd be happy to go over various options with you!
-Ray
Kelcema Audio
Mal Brown
« Reply #8 on: October 23, 2017, 01:34:24 pm »
Thanks Ray, You've been on my meeting list for a while.
WillyandNelson.com
Mal Brown
« Reply #9 on: October 23, 2017, 01:35:18 pm »
Appears to be in the FCC no-go band from what I can tell.
WillyandNelson.com
Pages: [1] 2 3  All   Go Up
Page created in 0.052 seconds with 24 queries.
