Pages: 1 2 [3]  All   Go Down
Author Topic: Danley: 2 x BC415 vs 2 x BC218  (Read 7377 times)
Len Zenith Jr
Re: Danley: 2 x BC415 vs 2 x BC218
« Reply #20 on: September 27, 2017, 08:22:07 pm »
Or, as Ivan suggests, video projection. Only problem with these that I can see is that potential haze/smoke would give away the source of light.
You'll only notice "the beam" when the source of light is shining towards you, when it is shining away from you, you don't really see it. In this instance only the DJ or the band would notice the projector beams or someone right at the cabinets looking back.
Scott Hibbard
« Reply #21 on: September 27, 2017, 09:14:00 pm »
I have heard a pair of the BC218s and the bottom end output is  mind blowing!
Still, 4 TH118s would be VERY good and probably lower cost.
If you install either sub configuration,  I hope you have good neighbours around the venue because that kind of bass gets around....everywhere!
Keith I'm more worried about the DJ! He's the one that is going to be deaf!
ScottH
David Allred
« Reply #22 on: September 28, 2017, 09:52:26 am »
Casting light (to illuminate the entire mouth) externally, seems problematic.  How will you keep people from blocking some or all of the beam?
« Reply #23 on: September 28, 2017, 11:38:37 am »
The subs would be a real problem with the light being blocked.
The full range cabinets, not so much.
┬ź Reply #23 on: September 28, 2017, 11:38:37 am ┬╗
Pages: 1 2 [3]  All   Go Up
Page created in 0.027 seconds with 22 queries.
