Author Topic: Spacing of Speaker Stacks  (Read 1335 times)
John Roll
« on: September 14, 2017, 09:26:09 am »
I have a benefit this weekend where I am probably going to be able to center cluster my subs. In the event that I can't, and this is something I never gave any thought to..distance between speaker stacks. The stage is ~20-25' wide. My stacks would go on the outside edges of the stage. However, should I be paying attention to how far apart they are. In other words, in terms of reinforcement/cancellation of bass frequencies, is there a critical distance or rule of thumb I should be aware of when setting their final placement? I will be running either center cluster (4 QSC HPR 181s or two stacks of two of the same per side)
John
John Roll
JMR Pro Audio
QSC, JBL, Presonus, Audix, K&M, EWI, Furman
Re: Spacing of Speaker Stacks
« Reply #1 on: September 14, 2017, 11:54:09 am »
John
As you change the spacing, the freq of cancellations will change, along with the position that you are interested in,
As a "general rule", you should keep the subs together or far apart.  Far apart means 40' or more, but that varies, based on other conditions, such as position of walls etc.
There is no "simple answer".
Jean-Pierre Coetzee
  • Gauteng, South Africa
« Reply #2 on: September 14, 2017, 11:57:52 am »
Run each side  in cardioid if your really worried about the cancellations, will help quite a lot with coverage but you might lose some power.
Sent from my SM-G900H using Tapatalk
Audio Technician
Word & Life Church
- Ivan Beaver
Jerome Malsack
« Reply #3 on: September 14, 2017, 02:06:06 pm »
80 hz is around 14 feet  so multiples of 7, yes each frequency is different along with each room.  The acoustics of the room will dictate how well the sound is.  If outside and not near walls or boundaries you will find that 14 and 21 will have some nulls and peaks.
Page created in 0.05 seconds with 23 queries.
