Author Topic: Which Ethercon?  (Read 3207 times)
Thomas Dameron
Which Ethercon?
« on: August 27, 2017, 05:28:08 pm »
For those of you building network patch panels for portable use, which ethercon connector are you using?  I'm building a few racks for Yamaha/Dante rigs with Cisco SG switches.  For this kind of application I haven't seen a compelling reason to go with anything shielded or cat6.  My client already has a decent inventory of unshielded Duracat, so unless someone has other experience I didn't see any reason to suggest a different course for them.  These will only go with these Yamaha rigs, so I'm not concerned with any Midas/Behringer/Digico compatibility.
Anyway, for the patch panel I was planning on using the NE8FDV connectors with an internal punch down.  I din't really want to do a feed through because it seems less like an extra point of failure.  All of these panels will have a lacing bar, so everything will be tidy and secure as possible.
Thoughts?  Comments?
Mods, feel free to move this to console connectivity if you think that's more appropriate.
thomas d.
Bob Leonard
  • Boston, MA USA
Re: Which Ethercon?
« Reply #1 on: August 27, 2017, 11:16:43 pm »
You may want a patch panel with those connectors in it just for audio runs to that panel, but, there no reason to make a special panel using those connectors for the LAN itself. More expense not needed.
The NE8 connectors/shell can be adapted to almost any quality RJ-45. The ground is not the ruggedized shell of the NE8 itself. So, if you feel that you will be re-patching the RJ-45 panel(s) frequently the use of a ruggedized jack/receptacle may be warranted, but other than that, no need for the extra cash spent.
BOSTON STRONG........
Proud Vietnam Veteran
Thomas Dameron
Re: Which Ethercon?
« Reply #2 on: August 28, 2017, 07:07:46 am »
Bob,
I may not have been clear on the intent of my panel.  I'm creating a patch panel with 6 pairs of primary/secondary locking ethercons in order to convert a pair of switches to a locking connector.  All other gear uses locking ethercons and all cabling has ethercons.
Which model of panel mount ethercon are people using?
thomas d.
Dave Bednarski
Re: Which Ethercon?
« Reply #3 on: August 28, 2017, 08:53:07 am »
I am using about a dozen NE8FDX-P6-B across the board for similar application, no issues across console or mixed data/ethernet traffic.  The feed thru side is well built and solid construction vs. the cheaper models with the exposed circuit board.
Bryan Hargrave
  • I'm one jammin' dude.
    • Soundworks of VA, Inc
Re: Which Ethercon?
« Reply #4 on: August 28, 2017, 09:20:37 am »
Hey Thomas,
I built an SG rack with 2 10's in it. Redundant and Secondary. 20 feed through connectors because I feel like a crimped connection locked in place is better than some punch downs out in the rugged world. I am probably worried about nothing. A little expensive but I don't have to take off connector shells anymore. I used unshielded cable because the only things in the whole world that require it are some MADI or AES50 snakes (not even all of either)... which don't pass through this since they are point to point. My switches are for control and dante.
Thoughts?  Comments?
thomas d.
Like us on facebook at Soundworks of VA, Inc.
Brian Ingwell
Re: Which Ethercon?
« Reply #5 on: August 28, 2017, 11:06:15 am »
Hi Thomas,
I'm with Bryan on this.  We've built several racks with SG switches to Ethercon patch panels.  On the first one, we we're originally going to go with punch down Ethercons, but after wiring up a few we just didn't feel like they would hold up bouncing around in a truck, so we swapped them out for the RJ45 feed through type.  With those, you can maintain the twist of the cable better and after about 4 years of solid use, we've had zero issues.
We also use unshielded cable from Link for Dante and control with no issues.
Just one person's experience.  YMMV.
Cheers,
Brian
Brian Jojade
Re: Which Ethercon?
« Reply #6 on: August 28, 2017, 11:52:35 am »
Thoughts?  Comments?
While either should be fine, I've seen more issues with punched down terminations than I have with crimped RJ45's and passthrough connection.  The advantage of using the RJ45 connection is that if something goes wrong or you change out gear, it's easier to just plug a new patch cable in if needed instead of messing around re-punching the connection.
Brian Jojade
Rick Earl
Re: Which Ethercon?
« Reply #7 on: August 28, 2017, 04:55:30 pm »
+1
We end up having a huge network for some events, devices over 1/2 a mile away, and there have been no issues from using these connectors, it also make re-configuring the racks easier. Our IT folks put sniffers on the line and can look at quality, not a single issue with any of our racks.
Bob Leonard
  • Boston, MA USA
Re: Which Ethercon?
« Reply #8 on: August 28, 2017, 11:01:16 pm »
Thanks for the clarification Thomas. For mobile audio use Brian's advice would be best to follow. Quality components will be the key to success.
Thomas Dameron
Re: Which Ethercon?
« Reply #9 on: August 29, 2017, 08:22:28 am »
Thanks for the input everybody, super helpful.  Good to hear from you Bryan!  Let me know next time you're in town.
Does anyone think theres an advantage to using the cat6 NE8FDX-P6 over the cat5 NE8FDP?  None of the other cabling will be cat6.  On one hand, the cat6 variant seems to be a one piece metal construction that looks a bit more robust.  On the other hand, assuming I build the panels well and strain relief everything correctly, I can't see how PCB on the cat5 version would come apart once it's assembled.  To me it's more a matter of the cat5 version has been the same for 10 years or whatever, and the cat6 is newer so perhaps Neutrik has learned a few tricks along the way.
thomas d.
Re: Which Ethercon?
Page created in 0.047 seconds with 25 queries.
