Author Topic: Simple remote volumes for SCM820?  (Read 1966 times)
Tim Weaver
  • College Station, Texas
    • Daniela Weaver Photography
« on: July 06, 2017, 01:32:30 pm »
So, I need to put a simple mixer into a room and the SCM820 does everything I'll need it to do. I would also like to have a remote volume knob for a few channels (ipod, PC, Lectern) and the only thing I can find is that the 820 is "crestron and amx compatible". I don't need that much control. I just want a wall plate with 3 or 4 knobs on it up by the lectern area. Is there a way to do this simply?
The last time I installed something like this was when the TOA 800 series was still current! lol
Craig Hauber
Re: Simple remote volumes for SCM820?
« Reply #1 on: July 07, 2017, 05:46:07 pm »
You may have to physically wire your inputs through custom variable attenuators which you build into your control panel.  If you are using inputs from a Dante network then forget it.
There are logic pins for mute/gate/override per input but no way to control gain.
Crestron wouldn't be too difficult to set up, but that added cost may make you consider a different DSP
For example, Ashly 24.24M gives you 4x4 with remote attenuators as well as custom iPad control panel capability for less than $1500
-even less if you look at dbx Zonepro
Craig Hauber
Mondak Sound Design
-Live PA
-Installs
-Theatre
Tim Weaver
« Reply #2 on: July 07, 2017, 09:33:33 pm »
That's a possibility I guess.
The attenuators would only be for the 2-3 local inputs. The dante inputs would not be controllable by the end users.
The Ashly would be great, but no Dante option.....
Craig Hauber
« Reply #3 on: July 08, 2017, 12:19:21 pm »
I wasn't clear on weather there were additional inputs.
One method I've also used, but adds a bit more in cost, is RDL VCA modules.  It does keep all the audio in the rack though with only voltage control lines running to the user panel.
http://www.rdlnet.com/product.php?page=523
Craig Hauber
Mondak Sound Design
-Live PA
-Installs
-Theatre
Cailen Waddell
« Reply #4 on: July 08, 2017, 03:47:26 pm »
The atlas blue bridge series will do what you need with Dante....
Scott Hofmann
« Reply #5 on: July 11, 2017, 09:35:27 am »
+1 for the RDL VCA modules. Relatively inexpensive and bullet-proof. As said, no audio leaves the mixer. Would be easy enough to whip up a 2-gang plate with 4 pots.
« Last Edit: July 11, 2017, 09:37:30 am by Scott Hofmann »
Scott Hofmann
Tim Weaver
« Reply #6 on: July 11, 2017, 05:01:57 pm »
This looks very much like the winner. Just got off the phone with Atlas and the remote panels can do some cool tricks which make this a very attractive option.
Page created in 0.067 seconds with 23 queries.
