Author Topic: (Noob Question) - Connecting antennas...  (Read 2529 times)
Stelios Mac
« on: June 30, 2017, 08:13:25 am »
I'll start by saying I've never really messed with wireless mics ever.
However, I borrowed a wireless Audio Technica setup to use for a show coming up the day after tomorrow, and I've gotten very confused in regards to how I'm supposed to connect the antennas, receivers & distributor.
The setup consists of:
- Two ATW-R3100 Receivers
- One ATW-DA49 Distribution Amp
- Two 3000 series condenser handhelds
When I received it, it had last been set up & used by a well respected local soundguy and was wired up like this:
I was under the impression, however, that Diversity receivers need to be wired up like this:
I also remember reading somewhere that antenna amplifiers can break if you don't have an antenna plugged in. Is that true? Which waυ should I connect them all?
Sorry for asking such a stupid question, the manual isn't horribly clear  :-\
« Last Edit: June 30, 2017, 08:17:45 am by Stelios Mac »
  • Old enough to know better
  • Audio Plumber
Re: (Noob Question) - Connecting antennas...
« Reply #1 on: June 30, 2017, 08:27:30 am »
You are right he was wrong.
Keith Broughton
  • Toronto
« Reply #2 on: June 30, 2017, 09:35:42 am »
The first diagram is wrong and maybe that person should not get involved in RF work.
The second diagram is correct.
If you follow the signal path, each of the 2 antennas is available to each receiver.
Remember to get the antennas up in the air for a line of sight to the transmitters.
Stelios Mac
« Reply #3 on: June 30, 2017, 09:43:19 am »
Good to know :)
Tbh I don't think he uses wireless mics frequently either, I can't blame him :P
The antennas will probably end up behind a curtain, on top of an amprack, just a few meters away from the performer, with no other obstacles in between. Do you think it's going to be a problem?
Thank you both  :D
Scott Helmke
« Reply #4 on: June 30, 2017, 10:13:08 am »
Points for both accuracy and efficiency in your response.   8)
Nathan Riddle
  • Niceville, FL
    • Nailed Productions
« Reply #5 on: June 30, 2017, 10:32:27 am »
Perhaps this 'respected sound guy' ran out of bnc cables? Benefit of the doubt?
Let thy speech be short, comprehending much in a few words.
-Apocrypha
Keith Broughton
  • Toronto
« Reply #6 on: June 30, 2017, 10:38:49 am »
Good to know :)
Thank you both  :D
Should be fine.
Page created in 0.043 seconds with 23 queries.
