Author Topic: Outdoor sound setup.  (Read 3873 times)
Steve Mason
« on: June 27, 2017, 01:14:43 am »
Hi all.
I am going to be doing sound for a small county fair this summer.  The venue is a open front, but enclosed stage.  Crowd will be probably 200-300 listeners.  Open dancing area in front of the stage puts the first row of chairs at about 25 feet from the stage apron and Crowd area extends back to beyond 100 feet from stage but the 25-100 foot zone is the area I am wanting to make sure I cover.
I am looking at running
4 (2 pairs each side)  Peavey 215's  700 rms @ 4 ohms
2 Peavey 118 Subs 400 watts at 8ohms and reinforcing these subs with a pair of old EV S18 subs 300 watts @ 8 ohms
Because I am on a budget I will be pushing everything with 4 Behringer INuke 3000 amps  880 per channel @4 ohms and 400 per channel @ 8 ohms
I know the 215's will handle the main duties as I have used them in a similar situation before.  My biggest question is about the subs.  They are what I have to work with.  Looking for recommendations on how to get the most out of them. Should I just go in straight pairs with 2 amps and 400 watts to each sub or would I be better off to buy one more powerful amp instead of 2 of the  Behringers and run a peavey and an EV in parallel per channel with a 4 ohm load?  I appreciate your time.
Gordon Brinton
  • ID Verified
    • Raw Depth Sound, Harrisburg, PA
Re: Outdoor sound setup.
« Reply #1 on: June 27, 2017, 03:42:14 am »
It depends on your volume level requirements. At first glance, I am guessing you don't have enough rig for the gig (period). With those top boxes, (90 degree horns,) highs and mids may tend to drop off a short distance out from the stage, (probably between 50 and 100 feet,) and they won't splay well. Your subs may not have enough oomph for outdoor work either if kick and bass are involved. Furthermore, mixing subs types is highly discouraged.
I would consider renting a more capable system or at least renting subs for this one gig.
Good luck.
« Last Edit: June 27, 2017, 03:46:47 am by Gordon Brinton »
Member since 2005.
Chris Hindle
« Reply #2 on: June 27, 2017, 08:13:25 am »
Stack the 215's, horn to horn. Twist for wider coverage.
don't mix the subs.
Put the Peavey's on one side, and the EV on the other. This will minimize any funkiness.
For 2 or 300 people, you won't be a rock star, but it should do just fine.
Chris.
John Halliburton
« Reply #3 on: June 27, 2017, 09:35:41 am »
don't mix the subs.
Chris.
I disagree.  The top config is okay, but I would cluster the subs all together in the middle on the ground in front of the stage to maximize their collective output.  I'd definitely test this first at the shop outside to make sure they are setup correctly(including all cabling, double checking for correct polarities across all the subs).
Best regards,
John
Thomas Le
« Reply #4 on: June 27, 2017, 09:58:10 am »
Consider renting better equipment. 2x15's are a bad idea unless they have a big HF driver ala SRX725 or similar. Your 2x15's are most likely 1 to 1.5 inch which will struggle. Echoing Gordon, add to the fact that the subs will be nonexistent and you can't splay because of most likely the tops are 90 degrees horizontal which will introduce comb filtering.
Chris Hindle
« Reply #5 on: June 27, 2017, 09:59:20 am »
Best regards,
John
Hi John. without decent measuring chops, my method will get the best results.
Trying to mix and match is troublesome at best. Custom EQ and delay always seem to be needed to even get close. I don't believe the OP has the tools or skill set to pull this off as a center cluster.
Hey, who knows. It is always possible that the subs will play nice, but I sure wouldn't count on it.
Chris.
Steve Mason
« Reply #6 on: June 27, 2017, 09:59:57 am »
Appreciate all the comments. I will have access to the venue so I can run everything up prior to the event. High volumes are not a huge factor as most of the bands will be more folksy and/or country.  No screaming metal or hip hop.
Ray Aberle
    • Kelcema Audio
« Reply #7 on: June 27, 2017, 11:16:10 am »
... and with that, I think you'll be fine. Will it be pound-you-in-the-chest bass? No, but it doesn't need to be. Will your system be capable of 105db(a) at FOH? Of course not, but it doesn't need to be. As is typical of smaller fair shows- it'll be loud up close and quieter quickly moving away from the stage-- and those who want to experience it loud will stick close to the PA.
Now to actually address the question you asked, instead of the one everyone else answered... ;) I think you'll be OK. Just set your gain structure well, and make sure you don't ask more of your gear than it's prepared to deliver. Keep them stereo; 1 box per amp channel. Chris makes a good point about keeping the same brand together on one side of the stage. (Although, to be candid, I don't think it would make any impact that someone would notice if you didn't...) If you were going to spend any money, though, buying a second pair of the same subs would be an interesting thought. (However, without knowing exactly what the rest of your entire show kit consists of, I cannot state that buying some more subs is the *best* use of your money to help this show be the best that it can be!)
But now, the main reason I posted... I'd love to break people of the habit of using "budget" to imply "limited budget." *EVERYONE* should be on a budget! It just matters how much money you can allocate to it overall -- that will impact a purchasing decision. Some shows have $250k or more to spend on production. Some only have $5,000. Some sound companies, if they need more rig for a weekend, just buy the kit they need, knowing they'll use it more in the future and pay it off asap. Others will be in your shoes- "I gotta make what I have *right now* work."
Now, from a business point of view, I am assuming that your client is aware of the limitations of your system, and that the performers will be OK working on this system? Because advancing that information with everyone involved is crucial. You do not want to show up, and find a b-level regional act asking you why the system for the charity auction the night before is still there, and their PA hasn't arrived. (They're being snarky, those wise-asses.)
If this system doesn't prove adequate, or even if it is, and the client just wants a larger system next time, then you can start the discussions early on-- "Yes, we can get a more substantial system, but that will be rented in, so naturally our audio budget will need to be increased." Communication is important, as is building rapport with the client. They need to see that you're in this to help them have a great show, and not just to put a bunch of more money in your pocket.
-Ray
Kelcema Audio
Sammy Barr
« Reply #8 on: June 27, 2017, 11:48:04 am »
I have been in a similar situation as yours running someone else's system.
Consider running a dual system with your two per side cabinets. Put vocals only in the inside cabinets and instruments in the outside cabinets and subs. It will allow for cleaner vocals and instruments and will minimize interference. It worked well for me.
Brian Jojade
« Reply #9 on: June 27, 2017, 12:22:43 pm »
If you're on a tight budget, WHY are you looking to buy gear for the job?  It's far less expensive to rent the gear that you need.  If you can't afford to rent the gear, then you are not charging enough for the gig.
Brian Jojade
Page created in 0.032 seconds with 23 queries.
