Pages: 1 2 3 [4]   Go Down
Author Topic: DSR 112 failure  (Read 6311 times)
Stephen Kirby
Re: DSR 112 failure
« Reply #30 on: September 12, 2017, 04:43:59 pm »
Is there a commonality to the age of failure?  The old A&H MizWiz/GL boards needed to have the ribbon cable connectors cleaned every couple of years.  If this becomes standard preventative maintenance on DSRs, then an idea of how long they last might help prevent embarrassing shutdowns on the gig.
Alan Norris-Elye
Re: DSR 112 failure
« Reply #31 on: September 13, 2017, 11:30:35 am »
I have had good results, by using a contact cleaner, then "NO-OX" electrical grease on the contacts.
Some connections were done years ago, without having any further problems.
I find that, as I get older, I drink less, but use alcohol as an excuse for my bad memory, more.
Jay Marr
Re: DSR 112 failure
« Reply #32 on: September 13, 2017, 11:47:08 am »
On DSRs?  Or other units?
Steve Litscher
    • 608 Sound and Light
Re: DSR 112 failure
« Reply #33 on: September 13, 2017, 12:19:19 pm »
Just so no one panics over this, I've owned several dozen of these over the past few years. The only failure I've had has been recently when I noticed one starting to fizz and sputter a bit when out in the sun all day. It always worked fine at the shop afterwards so it took a while to troubleshoot but I finally started to notice a pattern. Anyways, Yamaha was aware of the problem, had me send the unit back and had it back to me by the end of that week. Working 100%. Yamaha service rocks if you do ever have issues.
We have 10 DSR112s and have yet to have an issue with any of them (knock on wood). For the money, they are truly outstanding.
Alan Norris-Elye
Re: DSR 112 failure
« Reply #34 on: September 13, 2017, 12:46:05 pm »
Mackie 1604, allen heath mixwiz.  Both had ongoing problems, that this seemed to resolve.  It is used to prevent corrosion between different metals in the electrical industry.
Sent from my SM-G930W8 using Tapatalk
Re: DSR 112 failure
Pages: 1 2 3 [4]   Go Up
Page created in 0.084 seconds with 23 queries.
