Author Topic: MR/XR18 torx sizes for rack set-up  (Read 1000 times)
David Allred
« on: June 17, 2017, 09:08:42 pm »
How in the world is this info not in the manual?  I am going to have to buy a set, but considering the number of bit sizes, I don't want to guess if it includes the 2 needed.
Torx?  Really?  At this point I should be glad they did not have the security stob.
Thanks.
« Last Edit: June 17, 2017, 09:33:07 pm by David Allred »
Mark Cadwallader
  • Helena, Montana USA
Re: MR/XR18 torx sizes for rack set-up
« Reply #1 on: June 18, 2017, 12:04:53 am »
Be glad they are using 6 lobed Torx fasteners, and not Allen type resessed hex. The hex fasteners do not take as much torque as do Torx fasteners. (There is more contact area with the Torx key.). Buy a full set and you are ready for the next project as well.  Note that Torx drive sizes are independent of whether the bolt (a cap screw, technically) is metric or SAE threading, so it is better than Allen wrenches.
Jean-Pierre Coetzee
  • Gauteng, South Africa
« Reply #2 on: June 19, 2017, 07:40:15 am »
This, its the most annoying thing every having the wrong allen key set.
Just buy a set of torx and you should ve fine. Best thing Ive done, just wish it has a t1 in it as well, mine only goes to 1.5
Audio Technician
Word & Life Church
- Ivan Beaver
Page created in 0.054 seconds with 19 queries.
