Author Topic: Yorkville UCS1 candle snuffer  (Read 1416 times)
David Allred
« on: March 24, 2017, 12:37:47 pm »
I have noticed that when I am directly behind a UCS1 (DJ mode with a table just above the NL4 inputs between it and me) that the unused NL4 port is like a fan blowing on me.  Should I pull the plates and silicone the input backs to stop the air from escaping?
Chris Hindle
Re: Yorkville UCS1 candle snuffer
« Reply #1 on: March 24, 2017, 12:44:18 pm »
Just plug in a spare NL-4 (you do have a couple of spares, right ?)
Chris.
Dave Pluke
    • BIGG GRIN Productions
« Reply #2 on: March 24, 2017, 12:46:13 pm »
Are they the NL4's with screw terminals?  I only use the spade terminal style inside speaker cabinets.
Could be an easy swap/fix.
Dave
Brandon Scopel
« Reply #3 on: March 24, 2017, 12:51:35 pm »
Where can I buy those in less then a quantity of a hundred
Sent from my VS987 using Tapatalk
David Allred
« Reply #4 on: March 24, 2017, 01:58:38 pm »
Dave
According to the components list, it is PCB mount.
Chris Grimshaw
  • Sheffield, UK
    • Grimshaw Audio
« Reply #5 on: March 28, 2017, 05:25:54 pm »
I've got a couple of NL4 connectors here that whistle if you push the cone (sealed cabinets). Plugging something in helps a little, but I'd probably just coat the whole thing in sealant.
The leak certainly can't be helping performance.
Chris
www.grimshawaudio.com
Page created in 0.033 seconds with 24 queries.
