Author Topic: When to use a backcan on a ceiling speaker?  (Read 5227 times)
Re: When to use a backcan on a ceiling speaker?
« Reply #10 on: March 11, 2017, 09:29:34 pm »
Just curious if anyone knew of a textbook rule of when to use a backcan on a ceiling speaker? More of my own curiosity than anything else...
Thanks in advance.
One important thing that most people miss, is to always run the wire from the speakers straight up from the speakers-a least a couple of feet-and then run over and down to the next one.
DO NOT lay the wire on top of the ceiling-especially a drop tile one.
Glen Kelley
  • El Paso, TX
    • The University of Texas at El Paso
« Reply #11 on: March 13, 2017, 12:21:52 pm »
Yes, please! And use the correct hangers to support the wire -- not just strapped to conduit or HVAC straps... I have had contractors back out to fix this more times than I can count. That and missing safeties on the back-cans. :o
Joseph D. Macry
  • Austin TX
« Reply #12 on: March 14, 2017, 11:54:34 am »
Aside from plenum requirements, a backcan helps limit unwanted noise spreading above ceiling to other rooms.
Joseph Macry,
Austin, TX
Craig Hauber
« Reply #13 on: April 15, 2017, 12:50:17 pm »
Yes, please leave that area clear for the HVAC, CCTV and Telco guys!
But seriously, I can't remember the last time I've installed speakers without integral steel back-cans!
A few times I've had to forcibly remove tops of old plastered-in cans to fit EVID's before.
All we do now on pre-wire for new-builds is place the steel rough-in rings for the finish contractors to go off of.
I've found that "canned" speakers sound better because the manufacturers are working with a known size and can port and tune accordingly.  Open-backed residential home stereo speakers have always mystified me in that how can they spec the LF frequency response when they have no idea what size space or insulation (if any) is going to be behind the speaker?
Craig Hauber
Mondak Sound Design
-Live PA
-Installs
-Theatre
« Reply #14 on: April 15, 2017, 01:22:19 pm »
The reason for not laying the wire on the ceiling grid is safety for fire fighters.
If there is a fire, they will often take the axes and rip  through the ceiling to find the source.
If an axe grabs a speaker wire and the guy pulls on it, the whole ceiling could come down on him.
Craig Hauber
« Reply #15 on: April 15, 2017, 01:26:36 pm »
I was making a joke Ivan.
Craig Hauber
Mondak Sound Design
-Live PA
-Installs
-Theatre
« Reply #16 on: April 15, 2017, 03:04:38 pm »
Yeah-but A LOT of trades simply lay the cables on the gridwork.
I was stating why is is a dangerous idea to do so.
Yes, it is more work to do it right, but in the event of a fire, it could cause problems.
Hal Bissinger/COMSYSTEC
    • COMSYSTEC
« Reply #17 on: April 18, 2017, 01:18:14 pm »
It's a NEC violation and for good reason. Consider generations of cable thrown up into the ceiling. That's unfortunately often the case since there are so many hacks that couldn't care less about codes and landlords who don't require tenants to remove any cable that they installed when they move out. I've seen it so bad that you can't even push up a ceiling tile. Think of what would happen during a fire when that spider web mess comes crashing down entangling a firefighter.
-Hal
Erik Jerde
« Reply #18 on: April 18, 2017, 02:49:36 pm »
This is the exact reason I used speakers with integrated backing boxes when I did my basement.  Otherwise each speaker would have been in a different enclosure.  Now they are identical and they sound like it.
Page created in 0.059 seconds with 23 queries.
