Pages: 1 [2] 3 4   Go Down
Author Topic: Tour Amp Racks designs  (Read 15106 times)
Scott Helmke
Re: Tour Amp Racks designs
« Reply #10 on: March 01, 2017, 12:30:17 PM »
What soundworld needs now is a rugged, tour quality, single cable, high capacity, field repairable, power+data connector. (Perhaps it already exists in MIL world?)
Meyer VEAM?  OK, probably not field repairable.
We've got some wedges with VEAM, slick but we eventually came to the conclusion that separate standard connectors would have been slightly easier and definitely cheaper.
  • Old enough to know better
  • Audio Plumber
« Reply #11 on: March 01, 2017, 12:53:09 PM »
Continue to use what you have until the inevitable upgrade to self-powered. Unless you are making a "+3db leap" in overall efficiency or payback, store your acorns.
...and a pay raise.
You can find some choices on page 13 of THIS CATALOG, they look like this:
Steve Payne
    • Soundworks of Virginia, Inc.
« Reply #12 on: March 01, 2017, 04:38:39 PM »
I get a boner looking at the LK catalog.
Steve Payne
like us on Facebook at:
https://www.facebook.com/SOUNDWORKSOFVIRGINIA
  • Audio Plumber
« Reply #13 on: March 01, 2017, 05:03:23 PM »
They make great products.
Steve Payne
« Reply #14 on: March 01, 2017, 06:19:17 PM »
Used LK150s on all of our analog snakes for many years.  Bullet proof.
Sent from my iPad using Tapatalk
Steve Payne
Jim McKeveny
« Reply #15 on: March 02, 2017, 07:49:12 AM »
I was thinking of something like a PowerCon w/cat6.
Steven Eudaly
    • Headline Productions
« Reply #16 on: March 02, 2017, 08:27:00 AM »
We also went this way when we finally purchased "big boy" splits last year. Very happy with the decision.
Stephen Kirby
« Reply #17 on: March 02, 2017, 01:04:01 PM »
Well, you couldn't do anything with a twist and high speed data.  A pull ring latch maybe.
Technically possible, but a lot of agencies to deal with...
Daniel Levi
Josh Millward
  • Meridian, MS
« Reply #19 on: March 05, 2017, 03:01:21 PM »
Hey all,
We will be building new amp racks over the next few months. I wanted to see what some of the regional and national houses are doing with amp racks. I would like to see how places are making their system packaging faster and more simple.
Distros, connectivity, ease of use, speed.
What are the things you've seen and thought, "that is a great idea."
It would be great to see some pictures.
Thanks,
Talley
Here are a couple of my thoughts:
1. Pocket doors are a must. I hate searching for and sorting through a stack of lids to find the right one for a given box. The Olympic Fastpack racks are a fantastic implementation as they also feature a shock mounted internal rack for the gear. The attached image is an Olympic 16RU Fastpack, though Olympic will make them in any size you want.
2. Internal distro should keep power input cable attached and have a place to store it. It does not need to be a lot of cable, but just 25 feet would be enough to provide easy connection to the main distro. It seems silly to me to have to provide another case to tote power cabling for the rack along with the rack. Your Distro should generally be located near your amp racks. However, if you need an extension, you can always add one. The attached image has a 25' whip with a 50A 240V California Plug on it to jack into a distro.
3. Networking hardware should be built into the rack and be a part of your system solution. The attached image has two Cisco SG300-10 network switches rack mounted in the back of the rack on the same rails that support the rear of the amplifiers. This provides Dante primary and secondary connectivity. In this case, the primary Dante network also provides control connectivity for the amplifiers.
4. In the case of the attached image, the I/O panel is on the front. It can easily be moved to the back. People prefer them different ways based on the types of gigs that they do. I do such a wide variety of things, I'll use them either way and be happy about it. I will say, clearly labeled I/O panels are a must. It should be obvious what is supposed to connect to where. There should be no question when it comes time to hook it up.
Josh Millward
Pages: 1 [2] 3 4   Go Up
Page created in 0.039 seconds with 18 queries.
