What is the recommended peak voltage for the TH118?
"Peak voltage" means different things-depending on how you look at it.
So follow along-and for more information regarding setting limiters.
The TH118 is rated for 1700 watts @ 4 ohms with a 6dB crest factor.
That is 82V.
6dB higher (peak power) would be double that voltage (double power =3dB, double voltage=6dB), so that would be 164V.
That would be the RMS value of the 6dB crest factor applied.
HOWEVER-a good number of amplifiers use the "peak" of the voltage waveform-NOT the RMS value of that same waveform, when setting peak numbers.
The peak is 1.414x RMS. So that is 232V (164x1.414). Which is the number that should be entered into the DSP.
BUT HOWEVER-remember that the AES test is a "near death experience" for a limited period of time. I do not recommend setting limiters totally based on this.
YES, my opinion was different years ago, but I have done a lot of testing (blowing up drivers) and my opinion has changed.
I am currently working on programming the DSPs for a system/job that has over 1,000,000 "available" watts in it. But the "watts into loudspeaker loads" is only around 650,000 watts.
So I have been spending a lot of time "watching and measuring the limiter action". I don't want to blow anything up on this job
What I recommend for "normal" usage is to set the voltage that is "peak", at twice the continuous rating. That is "assuming" that the peak value presented is 1.414 the RMS value.
So that would equal the "program rating" (twice the continuous rating) of the driver.
Now this is where it gets interesting.
Not all thermal or heating limiters act the same. Some are VERY different than others-so it is very important to understand how they work and this helps to guide setting the RMS and thermal limiters.
Let's say you set it for 3 seconds for a large driver such as a sub.
Some of them start to reduce the level as soon as this level is exceeded and it takes 3 seconds to reach the set voltage-or at least 80% of it. I consider this to be "normal operation of a limiter".
Others (like in the Crown) wait for 3 seconds and THEN start to reduce the level. Nothing happens (in the thermal limiter section) until this level has been exceeded for that time period.
The overall action of heating on the voice coil is different for these 2 types of limiters.
So for the Crowns, my current recommendation of limiter settings are as follows.
ALWAYS turn the amp clip eliminator ON. This is NOT in the limiter section, but rather in the output block (last block?)
After you have set the xover settings, hit the "automatic" button for the release times.
This will set your release times based on the xover freq.
Then turn it to advanced.
Figure out the continuous voltage rating of the loudspeaker (in the case of the TH118 this is 1700 watts or 82V).
Halve this value (41V) and put that into the thermal limiter with an attack time of 3 seconds.
Double this value (164V) and put that in the peak limiter.
Now multiply this (42V) by .707 and enter that into the RMS value =58V.
Of course it never hurts to drop any of these values a tad for a little more protection without really affecting the actual SPL enough to be realized.
In this case I would use 80V as the starting point.
Hopefully that helps a little.
