Sound Reinforcement - Forums for Live Sound Professionals - Your Displayed Name Must Be Your Real Full Name To Post In The Live Sound Forums > Lighting Forum
DMX Automation
Doug Hart:
--- Quote from: Josh Rawls on February 22, 2017, 03:54:11 PM ---A quick google search came up with this:
https://wiki.openlighting.org/index.php/Open_Lighting_Project
http://www.instructables.com/id/Raspberry-Pi-as-a-DMX-light-controller/
http://www.raspberrypi-dmx.com
I think you can probably make a great solution using those links. Good luck!
--- End quote ---
Thank you !!!
Len Zenith Jr:
Showxpress is a relatively cheap software DMX controller that has auto on/off features that will even take into account the changing sunrise/sunset times as the days change. It has offset times to start/end a little earlier or later. You could even have it auto turn green for st paddies day, red for valentines, etc, etc. The whole year could be pre-programmed. No end to the programming you could do.
It is a free download to play with it. The time features are accessed via the live menu, right click a scene/macro button, then select button trigger.
Doug Hart:
--- Quote from: David Allred on February 22, 2017, 04:09:45 PM ---The complicated and expensive way would be to connect a photocell to a PLC that fires solenoid pistons to compress the appropriate buttons. It would be a neat project.
--- End quote ---
I have an electrical engineering buddy who is contemplating that very thing for me. haha
--- Quote ---What about a wireless option? You still need an operator though.
--- End quote ---
I thought about that too. Although it would make it easier, it would still require someone to be on site twice a day.
Doug Hart:
--- Quote from: Len Zenith Jr on February 22, 2017, 04:30:56 PM ---Showxpress is a relatively cheap software DMX controller that has auto on/off features that will even take into account the changing sunrise/sunset times as the days change. It has offset times to start/end a little earlier or later. You could even have it auto turn green for st paddies day, red for valentines, etc, etc. The whole year could be pre-programmed. No end to the programming you could do.
--- End quote ---
I will check that out. Thank you so much !!!
Len Zenith Jr:
--- Quote from: Doug Hart on February 22, 2017, 04:32:40 PM ---I will check that out. Thank you so much !!!
--- End quote ---
Now my LD mind is getting carried away, but you could even blink the lights 9 times at 9pm, 10 times at 10, like a clock, etc, etc. So much fun!
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
