I am seeing the clipping on the mixer but thank you for this information. It helps me understand what the Mic Offset is for.
Ron
That was simply a copy-n-paste from the manual. Hopefully you still have that floating around...
And re your mention of Hi vs Lo RF power- that's just for the transmission power, not the actual signal sensitivity. We typically keep ours on low, unless we're working outdoors or in a large space where there's a need for longer distances between the transmitter and the receiver. (Or, if you get interference from an outside source, boost the transmit power to keep your signal the priority at the receiver.)
-Ray
