Author Topic: High End DP2k artnet node  (Read 1996 times)
Aaron Talley
« on: February 15, 2017, 09:21:48 pm »
So we have some HES DP2ks we use as artnet nodes with our Hog4 consoles.
I just had a guy call desperately trying to find an artnet to use with his MA2 command wing because his physical ports are full and he's out of time to get anything else.
So I told him about the DP2k and how we use them. He told me it wouldn't work cause its Hog and he's MA.
I've never tried it. It's just artnet right?
Thoughts?
Jano Svitok
  • Bratislava, Slovakia
    • zvukari.sk
Re: High End DP2k artnet node
« Reply #1 on: February 16, 2017, 05:51:24 pm »
Erik Jerde
« Reply #2 on: February 28, 2017, 01:50:08 am »
Thoughts?
Should work fine.  The MA setup will be limited by the number of parameters (ma speak for dmx channels) his hardware activates.  If he's got 2048 parameters then it's just a matter of routing the proper parameters to the proper ArtNet address.  As long as the DP2k isn't doing anything hog specific it will work fine.  I haven't ever tried MA to DP2k but I've used it with enttec ODE nodes without problems.  If he needs more parameters (not just physical outputs) then he's out of luck and does need actual MA hardware.
James Feenstra
« Reply #3 on: March 04, 2017, 06:30:40 pm »
Assuming the dp2k speaks artnet and not hognet it should work
Elevation Audiovisual
www.elevationav.com
Taking your events to the next level
Page created in 0.03 seconds with 23 queries.
