Author Topic: Y Cable at the back of an amp  (Read 4471 times)
John Luty
« on: February 12, 2017, 09:56:22 pm »
if I were to use a Y cable at the back of my amp instead of daisy chaining from the speaker would that still be a 4 ohm load to each speaker ?
Ray Aberle
    • Kelcema Audio
Re: Y Cable at the back of an amp
« Reply #1 on: February 12, 2017, 09:58:31 pm »
So, you're saying both speakers are plugging directly into the amp, as opposed to amp --> speaker 1 --> speaker 2?
If so, then yes, the amp is seeing the same impedance either method.
-Ray
Kelcema Audio
  • Old enough to know better
  • Audio Plumber
« Reply #2 on: February 12, 2017, 09:59:43 pm »
If you mean a Y cable that splits the output of the amp so a separate cable goes to each speaker, yes, the impedance will be the same. The advantage is that there may be less loss in the speaker cables since you will have more copper.
John Luty
« Reply #3 on: February 12, 2017, 11:11:27 pm »
yes y cable plugs into the amp speaker "A" into one of the y's speaker "B" into the other . I as pretty sure the ohms would be the same just a brain fart . Doesn't hurt to reaffirm
Thanks
« Reply #4 on: February 12, 2017, 11:54:22 pm »
Thanks
It's really incorrect to use the term "ohms" as a noun in the manner you did.
Since this is a forum with an educational mission let me try and help fill in your knowledge.
Thinking in terms of a constant value of an ohm does not help you understand the relationship of a speakers impedance and the relationship to the amplifier.
An OHM is a unit of electrical resistance.  It is used in both AC and DC electronics.  Audio is AC and as such has another characteristic called reactance due to the presence of the voice coil (an inductor) in the speaker itself.  Since music is an ever changing, complex AC waveform the actual impedance the loudspeaker presents to the amplifier is a function of both the frequency and the level of the signal.  Impedance also changes due to other factors such as the construction of the cabinet (speaker has to work harder to overcome the backpressure of the air inside the enclosure) and heating of the actual voice coil as the speaker is utilized.
This is why the impedance value of a loudspeaker is a nominal value.  It is a representation of the average impedance of the box over it's entire operational range.  The actual impedance of the loudspeaker could vary more than 50% of the total range of the loudspeaker.
When connecting speakers together it is very important to keep this relationship in mind as most amplifiers have trouble driving low impedance loads.  Once you start connecting speakers together you could be presenting a load to the amplifier that is too challenging for it and could lead to premature triggering of the protection circuit.  At least premature compared to where the protection would engage at a higher impedance.
Lower impedances cause the amplifier to produce higher voltages and you risk rapidly damaging the loudspeakers.
As Ivan always says "it depends" connecting a single 8 ohm speaker to an amplifier output gives you much margin for error.  Once you begin to connect multiple speakers you erode that buffer.  Parallel speaker connections is a very complex topic.
Chris Grimshaw
  • Sheffield, UK
    • Grimshaw Audio
« Reply #5 on: February 13, 2017, 05:56:09 am »
Think you mean higher currents. Most amps are constant-voltage devices. Drop the impedance, and current goes up.
No added risk to the speakers, they're all seeing the same voltage.
Chris
www.grimshawaudio.com
« Reply #6 on: February 13, 2017, 07:35:20 am »
I will disagree a little bit.
The impedance ratings of speakers is often NOT any sort of average.
If you look at the ACTUAL impedance curves, in some cases the ratings are a good bit "off" of the actual impedance.
The "nominal" ratings given are the "closest standard" number.  2-4-8-16 ohms.
BELIEVE ME-anything other than that just causes lots of confusion.
Years ago I rated a full range loudspeaker at 6 ohms-since I felt that number was a "good average" and representative of the load it placed on the amp.
I got LOTS and LOTS of calls from people asking what amp to use-because they could find any amps with 6 ohm ratings.
I changed the impedance rating to 4 ohms on paper (nothing changed in the cabinet) and the calls stopped-except for a few asking why the impedance changed.
It is for that reason, that is IS important to look at the actual impedance CURVE-and not just a simple number.
At some freq, the actual impedance could be several times (much more than 50%) higher than the rated impedance.
The only real concern is when the impedance gets much lower (and for a wide range of freq) than the rated impedance.
So-as with most audio questions, you MUST ASK "At what freq?"
« Reply #7 on: February 13, 2017, 07:38:46 am »
Chris
Until the amp starts to run out of current-then the voltage going to the speakers will drop.
Which is actually less "power" going to the speakers.
As you say-amplifiers are constant voltage devices (they have a preset amount of gain that is not dependent on the output load), so they will produce the same voltage with no load and with a full load (up to the current capability) and will not change (at least enough to worry about)
John Rutirasiri
« Reply #8 on: February 13, 2017, 10:29:30 am »
Ivan, I've encountered several speaker mfgs that quote nominal impedance as the standard impedance (2,4,6,8) closest to the LOWEST impedance they expect the speaker to present.  So if it's 5 Ohms, they will say 4 Ohms.
Now I don't know if this is the right way to do it, but it is important in calculating what to set the amp limiter to.  It gives that little extra "headroom."
John R.
ClearImpact Sound & Event Services, Inc.
Sound/Lighting/Corporate A/V
"If it ain't broke, make it better."
DavidTurner
« Reply #9 on: February 13, 2017, 11:23:33 am »
Customer: "I need a new speaker for my bass amp"
Me: 4 ohm or 8 ohm
Customer "no, I just need 1 of 'em"
Page created in 0.024 seconds with 19 queries.
